Old 04-05-2008, 11:43 AM   #1
mexgrhd68
mexgrhd68's Avatar
Smile 700R4 conversion
I plan on installing a 700R4 in my 68, do I need to change steering column to do this conversion in order to get that extra gear?
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 04-05-2008, 11:52 AM   #2
cameeks
Long Fleet Club
cameeks's Avatar
Re: 700R4 conversion
I converted mine. It was a Power Glide befor I switched it and I can hit every gear.
If you are making a parts list add this TCIŽ 700R4 Constant Pressure Valve Body it will keep you from having low pressure from having the TV cable slightly off. With the TCI kit you don't have to go through all the trouble in trying to set the cable just right to keep it from messing up the trans. The valve body makes it to where the only thing the TV cable is for is to adjust the shift points. The bowtie overdrives kit keeps it where the TV cable adjusts the shift points and what pressure the transmission is at.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
