Old 04-05-2008, 04:11 PM   #1
Zilverado
Zilverado's Avatar
Power "On" - but no Crank
Hey Folks.
So it feels like absolutely FOREVER since I've posted - I've nosed around at times, but have just been a bit pre-occupied. It's great to see that this place is still hopping, despite the INSANE fuel prices.
So, for the past week, the Chevy's been our daily driver as I dealt with "no-crank" issues on our Pathfinder. The very day I got the Pathy running, a similar problem comes up with the Chevy - now it's dead on the driveway (thank goodness it waited as long as it did).
The problem...
Absolutely nothing when I turn the key to the "start" position. Full power to all accessories, headlights, etc., just nothing to the starter - not even a relay click. This is the case both in Park and in Neutral.
No blown fuses (at least not in the cabin panel), and battery and terminal connections are spotless.
So, is there a relay somewhere I should be checking? Anything else?
Thanks so much.
Zilverado is offline   Reply With Quote
Old 04-05-2008, 04:18 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Power "On" - but no Crank
battery cables, dirty connections?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-05-2008, 04:24 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Bad starter? Give it a couple taps with a hammer or something, then try to start it...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-05-2008, 04:28 PM   #4
Zilverado
Zilverado's Avatar
Certainly not on the top side. The lead cable terminals (ends) are almost brand new, as well as the battery. There is not even a hint of corrosion anywhere near the battery. Now, I have not actually taken a look underneath at the starter end, but I suspect I'll need to do that as soon as possible. I just thought I would get some ideas to hunt down.
Thanks.
Old 04-05-2008, 04:33 PM   #5
slug
slug's Avatar
a bad fuseable link might be the culprit. check all your wires going to the starter. give them a squeeze with wour fingers. if a fuseable link is bad it will be soft.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-05-2008, 04:40 PM   #6
Zilverado
Zilverado's Avatar
Wow! thanks so much guys for all the quick replies. Unfortunately, I am sick at home to day, and do not feel up to crawling around under the truck. You've certainly given me a few directions to look, once I feel up to it.
Keep 'em coming...
Old 04-05-2008, 07:56 PM   #7
harnalien
TruckincrazY
harnalien's Avatar
don't know if this helps, but that's exactly what happened to my '02 tahoe, and it was the starter. worked fine that morning, drove to breakfast, came out, and kaputt.
harnalien is offline   Reply With Quote
Old 04-07-2008, 11:34 PM   #8
Zilverado
Zilverado's Avatar
UPDATE!
So I removed the starter and had it tested - worked fine. So I moved onto trying to trace an electrical problem.
The main battery lead has power. The smaller lead to the solenoid, which I assue should get power when the key is turned, has none. So I trace the wire back to the fire wall where it goes into a junction box (photo). I am assuming this is the location of the fusible link???
Red Arrows - Fusible link? This wire is EXREMELY soft. feels nore like a piece of soft tubing than a wire.
Yellow Arrow - junction from one wire (fusible link) to two wires.
Green Arrow - This wire seems to run continuous and is very stiff. Is this also a fusible link?
So is this my fusible link? Any other thoughts on how to test this stuff?
Thanks.
Old 04-08-2008, 12:02 AM   #9
Pyrotechnic
Pyrotechnic's Avatar
Sometimes either the Park/Neutral safety switch or the ignition switch on the steering column come loose and the rod doesn't actuate it. Happened on my 78.
Pyrotechnic is offline   Reply With Quote
Old 04-08-2008, 04:17 AM   #10
lurch115
lurch115's Avatar
i had the ignition switch go bad in my 4x4 and it did the same thing...click but no start unless i tried it about 30 times then it would roll over....
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 04-15-2008, 05:20 AM   #11
Zilverado
Zilverado's Avatar
Well, thanks again for all the suggestions here. Just thought I would update and "close" this thread...
On Friday after reinstalling the starter that "tested" ok, the truck fired right up. Then I tried the key again and nothing! After rapping on the solenoid (I had tried this earlier), it fired again.
So, I spent the $120 on a brand new Hitachi starter (not rebuilt), and all has been great since. In fact, the truck has never turned over as rapidly as it does now - - that's one healthy starter.
So, thanks again for all the help, but it looks like the starter was the problem after all.
Old 04-16-2008, 04:31 AM   #12
1975stepside
Stepside Fanatic!
Sometimes the starter motor's brushes are worn out and/or sticking and not making correct contact. When you haul it out and take it to the starter shop for testing, the brushes will sometimes loosen up and work again...for a while. And then soon after you reinstall it, they malfunction again, Hence the "it tested good at the shop" scenario that you will hear about time and again.
1975stepside is offline   Reply With Quote
