04-05-2008, 04:17 PM | #1 |
Pics plus electric fan
I got my electrica fan setup done based on this post another cheap electric fan build! . The fan will be controlled by a SPAL programmable controller. Here are a few more progress pics. I started this truck in 2000 and I just started working on it again. It is a little bit of a 68 and 72 GMC along with a 74 Chevy.
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
04-05-2008, 04:37 PM | #2 |
More Cowbell....
Re: Pics plus electric fan
Nice.
Oh, by the way, you have a headlight out.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
04-05-2008, 04:53 PM | #3 |
Junior Member
Looks real good so far.
Danny |
04-05-2008, 05:50 PM | #4 |
On the fast track to nowhere..
Clean install, I like it
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
04-06-2008, 05:50 AM | #6 |
Retired Air Force 87-09
Nice and clean. Did you think of writing this up for the Faq section? Wold be a nice mod for anyone to do.
Rich |
04-06-2008, 06:12 AM | #7 |
I'd so be doing this if I had a fan shroud. lol.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
04-06-2008, 06:21 AM | #8 |
Is that your shop? I like it, we have a similar lift in our shop, but ours is Asymmetric
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-06-2008, 02:41 PM | #9 |
already in the FAQ. Write up was done. Installed mine a while back. Works great.
1997 GMC Sierra Ext 1965 Mustang |
04-06-2008, 02:55 PM | #10 |
laying low
In a recent thread concerning using that Jeep fan and towing the poster noted his temps were up using this fan only. A Jeep mechanic said the Jeeps use that fan only for normal applications and that fan plus an engine driven fan are used together on Jeeps with a towing package. Worth keeping in mind for anyone who might be doing some extended towing and depending on this fan to keep it all cool.
Real nice installation here though. Your attention to the mounts is great.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-07-2008, 07:44 PM | #11 |
The origional posting has the fan mounting from the inside of the shroud. This one is mounted from the outside and looks much cleaner. The mounting difference could be added to the original post to give folks a choice of mounting options.
04-07-2008, 11:35 PM | #12 |
I agree this is a cleaner mounting. Very nice.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
04-08-2008, 03:07 AM | #13 |
I have the fan and plan to do this in the next few months as well. I like the mounting setup you have too. Looks like you slotted the shroud and used some rubber spacers for the two upper mounts. Correct? Did you make or buy the rubber block spacers? And that bracket on the bottom, did you fab that up as well?
Mark
71 Cheyenne SWB |
04-13-2009, 05:35 PM | #14 |
A bump since I'm ordering this right now.
Here's where I'm getting it from, I called and confirmed that they have it. http://www.trademotion.com/partlocat...&siteid=214583 Just enter the part number and select jeep in the drop down menu.
04-13-2009, 05:47 PM | #15 |
Part number is: CBG4F250
Since I can't seem to edit my posts.
04-13-2009, 06:17 PM | #16 |
dazed and confused
I am wanting the do the same thing. the only problem i seem to have is i cant seem to get my fan shroud to fit my truck. it has a v8 in the v8 location(sbc 350). it has long water pump and sepertine pulleys off of a newer truck.it hits the bottom pulley. do i need to trim the shroud to have enough room or do ihave the wrong shroud? where there different ones? sorry about the long post. this shroud came off a 68 chevy truck.
members met: redbaron69, billsbowtie,nc67 |
04-13-2009, 06:26 PM | #17 | |
Thanks for that! I was having trouble with the "moparparts.com" website everyone else was using. I would create a user account with all my info, but it would never let me log in to check out. I tried a couple different times and nada. Never had that problem before, so I gave up. Their price plus shipping is almost exactly the same.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-13-2009, 06:36 PM | #18 | |
Happy to help out a fellow Jesse James.. how odd is that?
04-13-2009, 06:37 PM | #19 | |
04-13-2009, 06:40 PM | #20 |
dazed and confused
i will see if i can get one
04-13-2009, 08:08 PM | #21 | |
Jesse James is my first and middle name. My pops named me.
04-13-2009, 08:12 PM | #22 |
ditto.
04-24-2009, 06:34 PM | #23 | |
Just fit mine up. I can tell you the truck in the photos above does NOT have a short waterpump in it. lol. It's incredibly tight on a truck with a long waterpump. Like 1/16" kind of tight. Mine will fit but I think I'm going to do some cutting on the fan mounting tabs or the shroud to get a little more clearance. It looks like I can get another 1/4" or so. This is without serpentine belts. So, I'd say it will not work for your application.
04-24-2009, 07:00 PM | #24 |
dazed and confused
thanks for the heads up! im not sure if i can trim mine that much and get the fan to work.
06-16-2009, 02:49 PM | #25 |
Sorry I forgot about this thread. This does have a short water pump on it, but this truck used to have a v-6 so it is not stock at all. I will have to keep an eye on the engine temps once I get this running but it is pretty impressive so far. You can drop a piece of paper a few inches away and it will suck it to the radiator.
