How to adjust shifter to align with indicator
I just recently pulled my steering column and painted it and replace some of the parts . Went to install last night and noticed that my shifter is off. If the indicator says it's in park, it's actually in reverse. If it says reverse, it's in nuteral...you get the point. What's the best way to fix it. I was thinking I could loosen the tranny linkage and reset the shifter to the correct positon on the indicator and then secure the linkage.... or is there a easier way or do I have bigger problems.
Thanks ![]()
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 04-05-2008 at 06:14 PM. |
I miss this truck.
Re: How to adjust shifter to align with indicator
Do you have a lot of play in the shifter? There is a bushing in the "ear" (for lack of a better term) on the column under the hood where the linkage attaches to the column. If that bushing is shot, it could be your culprit.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#3 | |
I replaced that. I have that problem in park, but the shifter is off one click. if it says indicator says reverse, the truck is in drive. the column is alligned with the dash and everthing on the column is center. I'm hoping someone else has had this problem and found the solution.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
Take the shift rod that comes off the column and loosen the nut on it. Then slide it up or down till its adjusted into the right gear. i took and shifted my transmission into park first and then moved my column into park then took up the slack with the rod.
It's a catastrophic success.
![]() Join Date: Jan 2003
Loosen the nut that holds the link rod to the column,put the trans in park by hand, put the shift lever all the way in park, retighten link rod on column.
Thanks for all the help, that's what I thought but wasn't sure, gotta love this site.
Thanks ![]() ![]() ![]()
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The problem you have is that you have one more gear now than the shift indicator shows.I don't think you can adjust the linkage to allow for that so what you need to do is contact the forum venders and get an indicator for a 700r4. Here is one.
http://www.gmcpaulstruckparts.com/pi...enswtiltod.jpg
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
its all about the +6 inches
nope, he has a 350/TH350... just needs adjusted.
Msgt USAF Ret
Yeah I see that now. RIF after all the posts I've read on the 700r4s and seeing how his post reads I just assumed he had one. Senility setting in.
LOL, we've all done it man.
