Old 04-05-2008, 09:08 PM   #1
DKN
Active Member
Affordable BIG Brake Upgrades for the 1963-1987 C10
Since there seems to be a lot of interest for a complete 13” truck brake kit for under $1k I thought that I would share some info on it for you.
There is a new 13” brake kit shipping very soon. The projected retail price is under $1k for a complete front kit and about $1.5k for the complete front and rear kit. Yes there is a rear kit already finished and in stock. These are all new parts. We made a new drop spindle that will not require any machining. We made this spindle so that you can use what ever brand brake kit you want. CPP currently is producing a 13” kit. Wilwood is making a 13” and 14”. We will be sending sample spindles to Baer and Kore3.
We made our kit with a PBR caliper. It is similar to the PBR Corvette caliper but it is stronger, has larger pistons, uses a larger pad, 1/3 the cost, and has more wheel clearance. It is a GM OE caliper. There are about 15 million sets produced already. The total piston area in our caliper is the same as the piston area in the original HD truck caliper.
The Corvette piston areas are 57% (40mm) and 52% (38mm) of the original HD truck caliper. This much loss in piston area means the system need about 2 times more brake pressure to work like it did originally. (I realize the rotor is 8% larger.) In most cases the rear brakes end up skidding before the front brakes can offer any noticeable stopping power. This is one of the major reasons we do not use a Corvette caliper.
We have been road testing the front and rear kit for more than 60 days now. It works great. We have also track tested the kit. The stopping distance from 60mph is 1/3 less than with the same tire and wheel on a new set of heavy duty brakes.
I don’t have pictures yet, but you can read more about this in Classic Trucks magazine. There is a color picture of the brake sitting on the ground on the cover of the February 08 suspension buyers guide issue of Custom Classic Trucks.
The link will show you the car kits; the truck kit is basically the same except that it will fit a truck, not a car.
http://www.classicperform.com/NewPro...igBrakeKit.htm
I know that this is a long post, but I keep getting loads of PMs asking about this, so here you go.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 04-06-2008, 02:01 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Affordable BIG Brake Upgrades fro the 1963-1987 C10
DKN,... thanks for posting. Sorry about the not so friendly welcome in the other thread. I have never purchased anything from CPP,... but am interested in this kit for my '86 swb. Please post part # when everything is in stock and ready to ship. Let your people that answer the phone know,.... that we are a tight knit group of truckers. We usually hang together and get the word out quickly if there is a problem with anything truck related out there. (also,... we let each other know when a good deal comes along!) Just let me say welcome to the best forum on the net. Thanks for sticking around. And,... we really like pictures!
Keith
Convert to disc brakes.
Old 04-06-2008, 04:27 AM   #3
Rokcrln
Rokcrln's Avatar
Re: Affordable BIG Brake Upgrades for the 1963-1987 C10
Welcome to the board. Looks like this will be a great up grade to our trucks. I have been driving mine on a daily basis and I am thinking about a break up grade. If you need any testers for you let me know I think Low Buck http://67-72chevytrucks.com/vboard/s...d.php?t=223158 would be a great test bed for your set up
Keep us posted for when they are ready to ship.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-06-2008, 05:24 AM   #4
68 short step
so when will this kit be available, the rear are 2 piston calipers too right?
also sign me up for a tester truck......
68 short step is offline   Reply With Quote
Old 04-06-2008, 05:26 AM   #5
bagged74
its just $$$$$
bagged74's Avatar
are you using a GTO caliper instead of corvette?
bagged74 is offline   Reply With Quote
Old 04-06-2008, 07:59 AM   #6
stunna
does the price include the spindles too?
stunna is offline   Reply With Quote
Old 04-19-2008, 04:21 AM   #7
DKN
Active Member
This kit is coming quickly, about 6 weeks or so. The only hold up is the foundry/machine shop, everything else is already built and in stock.
The rear caliper is a single piston with built in parking brake. We use the caliper with the integral parking brake because there is no “kick back” caused by the clearances and slop in the C-clip axle. This gives a better feeling brake pedal.
We use a GM 6 lug truck/SUV caliper and pad. GM sold over 1.5 million sets per year. They are found on the 6 lug Chevrolet, GMC, and Cadillac vehicles from 1999-2006. These vehicles require a bigger/better brake since they are heavier vehicles with a large towing capacity unlike the light weight Corvette.
The $1K price includes new spindles and new aluminum hubs as well as all the rest of the parts you need to finish the install.
As for the part numbers: It would be best to call. Our kits are very complete, and the part number varies by the year, and brake set up. This is done in order to accommodate the different parking brake cables, boosters, ball joints, tie rods, hose configuration, hard lines, clutch cylinders etc. We make these to be direct bolt on kits. You do not need to buy different ball joints, etc.
Danny Nix
CPP
Old 04-19-2008, 06:03 AM   #8
SBTork
Garage wrench
SBTork's Avatar
welcome to the site, it's good to see someone from cpp here, i've always like their/your products. I think I may have to call on a set of these once my '86 gets further along.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-19-2008, 08:37 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
WOW. That setup looks awesome. Are the lower control arms available to work with air bags, similar to ART's StrongArms?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-19-2008, 03:55 PM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet! please post a pic of all the parts for a front and back kit so we know what is in it.
Thanks,
Trav
tvblazer78 is offline   Reply With Quote
Old 04-19-2008, 04:25 PM   #11
DKN
Active Member
Yes the upper arms are the same. The lower arm kits are either coil or air bag.
http://www.classicperform.com/NewPro...ubularArms.htm
All of our arms ship fully assembled with bushing, shafts, ball joints and bump stops installed.
Danny Nix
CPP
Old 04-19-2008, 05:14 PM   #12
smashingchuck
In an effort not to take this thread anymore off topic, I've sent you a PM.
78 Build Thread
4Runner Build
Old 04-19-2008, 06:08 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Nice. I have a few questions if you don't mind answering them:
- Will the spindles and brackets be available seperately?
- What rotor are you using? Is this an off the shelf replacement item?
- How much does this narrow the front track width?
- What diameter wheels are needed to clear?
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-20-2008, 07:48 AM   #14
Brad
Out of the carpool lane.
Brad's Avatar
Question Re: Affordable BIG Brake Upgrades for the 1963-1987 C10
Thanks -Chris
I'm curious also. I'm very concerned about being able to buy replacement rotors in 5-10 years off the shelf rather than finding out your company is no longer making rotors for this. Seems many folks are coming out with the big brake kits and getting solid info on the rotors is more than a bit fuzzy which is the major obstacle for me in purchasing anyones kit. I'm willing to buy a kit in the whole, but with the condition I can get a replacement rotor at any LAPS at anytime. Otherwise I'll just stick with my OEM disks. JMHO.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
