1968 gmc 3/4 with Leaf Q hellp
my install shop found the back leaf shakcles bad .. so I bot new ones 29.95 local .. now he sez need the brackets to hold them .. does anybody make them ? .the spring shop sold my some Ford brakcets .. said drill new holes and used them ... what should I do ????
Re: 1968 gmc 3/4 with Leaf Q hellp
The rears? You might be able to get lowering ones for a 73 and up truck. Does yours have 2 1/4" or 2 1/2" springs? 2 1/4" more common, but Longhorns and 4x4's have 2 1/2". Junkyard probably your best bet.
I think you`ll have the wider ones in`68?You could drill for the Ford brackets.But,if time isn`t so tight,try to find the originals.See if any are being parted in the parts section.If you want to lower,then the lowering brackets mentioned will do the trick.I know LMC has them,since I know a guy bought them.
What was the problem with the brackets?
![]() Join Date: Aug 2005
I ran into this on my truck. Had a hard time finding rear spring bushings, as '67 and '68 rear leafs were narrower than '69-'72 (Mike C is right, '67 and '68 4X2's are 2.25"). I was told that many Ford pickups had 2.25" wide rear springs. If that is true, you probably could make the Ford hangers work. I would think you probably could find someone around here with the right ones though.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 04-06-2008 at 10:32 AM. |
If you find 2.50" bracket you can always use spacers.I guess I had it backward on the width.I knew they weren`t the same as`69-up.
