04-06-2008, 01:44 AM | #1 |
taking my 305 out of my truck!!
im taking out my 305 and puting in a 350, how hard is it to do, i tryed cranking on the bolts that hook to the transmission buti couldnt get them to turn, is there anything i really should know before doing this?
girls love guys like me!!!!!! |
04-06-2008, 03:30 AM | #2 |
Re: taking my 305 out of my truck!!
Wel if your having trouble with the bell housing bolts..............you might want to get a buddy to help you with it.Not trying to be a smart A$$,but..
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
04-06-2008, 03:36 AM | #3 |
Parts and more parts
What experience do you have in this area? That will tell us where to lead you on this project.
04-06-2008, 04:17 AM | #4 |
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
04-06-2008, 04:49 AM | #5 |
Robert Olson Transport
its not that hard the trick of it is to try and do things systematically so you do things in order
first drain the coolant disconnect the battery remove the radiator and hoses remove air conditioning hoses remove power steering pump and lay to side disconnect smog stuff if any remove alternator and belts lay wiring to side remove bolts that old exhaust manifolds to heads disconnect plug wires and remove distributor disconnect fuel line drop inspection pan and starter remove the motor mount bolts loosen / remove the six motor to trans bolts remove the torque converter to flywheel bolts yank motor out using a pry bar and hoist install is reverse of removal someone reasonably mechanically inclined could do this over a weekend
04-06-2008, 05:13 AM | #6 |
Why does it taste purple?
Easy as pie.Im goin to be re-installing the engine in my truck this coming week.It took me less than 2 hours to yank it out,lets see how long it takes to put back in lol.I have done a complete swap in a 85 Caballero in less than 8 hours.That was including the 2 hours spent trying to get the "Direct fit" headers to fit right
04-06-2008, 05:49 AM | #7 |
i have mostly everything you said disconnected, i am pretty good mechanically and my buddy did it with his 74 nova, i was mainly worried about how i get to all the bolts that hook from the transmission to the block and how to disconnect the flywheel from the clutch, i couldnt really get a picture that looked good
04-06-2008, 06:41 AM | #8 |
ive never done a standard trans without removing the trans first and removing the motor with the bell housing then once out of the car doing the clutch and all
04-06-2008, 08:09 AM | #9 | |
i agree...it is genrally easier to separate the bellhousing after you pull the motor....with automatic trannys it is easier to separate the tranny and motor after its out also....dunno if you can pull motor and tranny out with a manual tranny though.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
