04-06-2008, 03:52 AM | #1 |
Tach dash cluster
I have an opportunity to get a stock tack dash cluster out of a 87 silverado, but my 87 gmc 1500 does not have this, anyone know if it will just plug in and everything work or if anything has to be done for the tach to work. I am assuming that everything else will only thing differetn between the two is the placement of the fuel gauge. Thanks to all.
One other question how does the tack work? what i mean is what does it plug into to get the rpm reading?
1979 Scottsdale Trailering Special K30 Motor City GMC |
04-06-2008, 04:34 AM | #2 |
Dirteh Kitteh
Re: Tach dash cluster
There's a whole bunch of posts about this in the Electrical forum. You'll need the tach pigtail harness to get it to work.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
04-06-2008, 04:39 AM | #3 |
I do not believe that there was a factory installed tach cluster in 87 . It is probably one someone put together . I would get it anyway and make sure it will work in your truck before you install it . Frank
Born and proudly residing in a Red State ! |
04-06-2008, 05:32 AM | #4 |
you'll need to run a wire from the ground side of the coil for the tach rpm feed. it should be marked on the hei cap already. otherwise just power and ground an you should be good.
04-06-2008, 06:45 PM | #5 |
yeller
I agree with Frank, tachs weren't put in 87's from the factory.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-07-2008, 04:34 AM | #6 | |
In the Forgotten far North.
'73 - '74 w/ pionts type dist & remote mounted coil hook the tach lead to the + side of the coil.CORRECTION- As pointed out by Mickey_D below that should be the - side of the coil. '75 - '86 with coil-in-cap H.E.I. plug the tach lead into the dist cap where it's marked "TACH" '87 - '91 models plug it into the white unused lead right near the coil. That is the tach lead from the coil. Run the positive lead from the coil to a "switched" (no power when key is off)power lead on the fuse panel. Run the ground lead to the 6 prong cluster ground located on the left side wall behind the cluster. And here's what you will see on the back of your tach cluster where the tach leads are located...................
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 04-07-2008 at 07:43 AM. |
04-07-2008, 04:39 AM | #7 |
Tachs were inthe medium duty trucks 87-89. That may be waht that dash is out of.
04-07-2008, 04:39 AM | #8 |
Dirteh Kitteh
Wouldn't that be the negative side of the coil there BLE?
04-07-2008, 07:40 AM | #9 |
Yep thanks for catching that. I'll go back up and correct it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
