04-06-2008, 04:12 AM | #1 |
"brand new second-hand"
a/c fan switch problem-
Once again, I must return to the masters of these fine trucks for some sound advise and shared wisedom! I read recently where someone had a problem with the fan control switch-it would go low, then medium, then back to low-but not high. Can anyone remember the fix? I put in a fresh switch-just r & r'd the heater core -cleaned the evaporater and detailed everything associated with the a/c-heating system. Just can't get the fan to blow on high. I did try the fan directly to the battery prior to install and it turns lots of rpm's hooked directly. This problem did exsist before I started on the project( that's why I had a new Idack switch.....any bells ringing??? help.....Steve
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
04-06-2008, 04:39 AM | #2 |
Re: a/c fan switch problem-
There is a relay on top of the heater box that is probably your problem. It also has a ground that goes from it to the fan motor and a ground that goes from the fan motor to the cowl.
69 Chevy 4x4 383 Power |
04-06-2008, 05:09 AM | #3 |
its all about the +6 inches
yep, more likely than not, this is the problem
04-06-2008, 05:23 AM | #4 |
I knew you guys had the answer! Thank You Haysonj-i'll get at it in the morning.
