04-06-2008, 04:57 PM | #1 |
Who's aftermarket A/C System would you suggest
I have a non A/C cab and want to add A/C. After looking around on the net there seems to be three different manufactures. Classic Auto Air, Old Air and Vintage Air. Which one is best and why? Is there another system I should consider? Any help would be greatly appreciated. Rodney
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
04-06-2008, 05:19 PM | #2 |
Re: Who's aftermarket A/C System would you suggest
I think there is a Hot Rod Air, but i'm not 100% on that. I've heard nothing but praise about Vintage Air
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-06-2008, 06:15 PM | #3 |
I have vintage in my 4x4 and wish like anything that it was factory air. It is noisy and the compressor brackets needed modification, hose connections are inside the cover which puts them inside the cab so more chances for a leak on the carpet, passenger side cab vent rod won't clear a/c box and recirculate only means that the windows fog over in the winter. I haven't found a setting on the thermostat that will keep the windows fog free and let the heater blow hot air. Check out past threads on this, some of the other guys on here are good on converting factory systems to an orifice tube set-ups. I'm putting factory air in my 72 non-air truck, cutting holes for the vents isn't as bad as it seems.
04-06-2008, 07:25 PM | #4 |
Classic Auto Air! If you research the products offered you will discover CAA is the "only" one to offer a duel core unit one for heat and one for cold, much more efficient and its how GM did it!
04-06-2008, 07:27 PM | #5 |
Forgot to add that CAA uses Spal fan units and they are quieter but all under dash units will be noiser than firewall mounted units.
04-08-2008, 01:47 AM | #6 |
My truck came with Vintage Air that was installed this past summer. It works good... the only problem I have is the lowest speed fan setting is too high. It froze me out last time it was hot. I was able to adjust the heat this past winter fine.
Any recommendations on slowing the fan down would be appreciated. |
04-08-2008, 04:50 AM | #7 |
Ive got a Vintage Air sure fit system in mine. I love it, I just put it in last year, my only regret is waiting so long
75 GMC C-15 short/step factory 454, lowered |
04-08-2008, 04:55 AM | #8 |
WTB this ad
I've got Vintage Air surefit systems in both of my trucks. Yes they are difficult to get them not to fog the windows in the winter but the A/C will run you out.
04-08-2008, 05:20 AM | #9 |
Before you buy any of those check out our local guy. Lucky's has a kit with defrost, heat and air for only $675! Here's some info. His site doesn't have the pic yet for the unit I am getting, but it's a very nice system that uses your dash outlets or you can plumb them anyway you want.
Lucky’s Rod & Kustom 1006 S. Kaufman Street Ennis, TX Universal A/C Systems & Street Rod Parts Specializing in Complete A/C Systems starting at $500, Sanden Compressors, A/C, Alt, Ps, Brackets, A/C Installs, Brake Kits, EZ Wire Harness and Power Windows, Dolphin Gauges, and LED Lights. Look me up on the web at www.freewebs.com/luckysrodandkustom Or give me a call or email for a free brochure at 972-875-2741/ my cell 469-337-9307. My email is street-products@sbcglobal.net Owner- Shane Gill
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
04-08-2008, 03:20 PM | #10 |
Thanks, I will check his out. Rodney
