Old 04-06-2008, 06:14 PM   #1
daman02
daman02's Avatar
Electric window motor install
anyone know how big of a chore it is to install new motors for the electric windows on an 86?
daman02 is offline   Reply With Quote
Old 04-06-2008, 09:04 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Electric window motor install
its not to bad if you have skinny arms it make it easier, there is 3 bolts holding the motor, but I have spot cut out for a speaker so it made it alot easier
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-07-2008, 02:06 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Check out this link from www.73-87.com. Look here: http://www.73-87.com/7387garage/interior/winmotor.htm
Keith
Convert to disc brakes.
Old 04-08-2008, 04:54 AM   #4
85 c-10
I changed both of mine in my 85 in less that 45 minutes. Not to bad, just stay calm and use your head.
Josh
85 c-10 is offline   Reply With Quote
Old 04-08-2008, 03:33 PM   #5
Rooster's82
Rooster's82's Avatar
Josh
Yup...i just put a new motor and regulator in my truck and it took about 40 mins...it was my first time, next time around it should take half that. Unfortunately next time around is going to happen sooner then i would like seeing how the "new" (from the junkyard) motor is toast.
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
