Old 04-06-2008, 06:15 PM   #1
Highsteel
Chasin' the Dream
Highsteel's Avatar
Electric coolant fan wiring relay
I got my fan installed and wired up according to the kit manufacturer specs I got from the parts store. All went well, temp stayed normal, until I went to turn the truck off. Now there is like a 2 second delay from the time I turn the key off til the engine turns off. Its not dieseling, it just stays running for a bit, then shuts down.
Is this because there is no relay? I have a relay that came with the (used) fan but I wasn't sure where in the circuit to put it.
Jerry
Highsteel is offline   Reply With Quote
Old 04-06-2008, 06:44 PM   #2
jhow66
jhow66's Avatar
Re: Electric coolant fan wiring relay
Your fan is acting as a generator while it is turning after you turn the switch off thereby adding a small amount of current to the system. When it stops turning, engine dies. Add a one way diode in the power wire to fan or add the relay.(between switch and fan)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-06-2008, 09:52 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would never even consider running a fan like that with no relay.
Jhow is 100% right though, the fan is acting as a generator and making enough power that it back feeds through the system and triggers spark to keep the engine running.
Old 04-06-2008, 11:28 PM   #4
Highsteel
Chasin' the Dream
Highsteel's Avatar
I guess if I possessed your unlimited and infinite wisdom I wouldn't have needed to make such a clearly ignorant post and you would not have had to make such a pompous and condescending reply. If I really wanted belittled like that I'm sure I could find a forum that catered to just that sort of treatment.
Thank you, jhow, for confirming my suspicions. I was pretty sure that a relay was needed, I just wasn't sure where in the circuit to put it.
Old 04-06-2008, 11:34 PM   #5
pcmcobra
pcmcobra's Avatar
I don't think he meant that in a "belittling" way, he was just making a statement, that he would not do it that way.
Anyway, ya a relay would help.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 04-06-2008, 11:40 PM   #6
67shortie
Green club
67shortie's Avatar
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 04-07-2008, 03:33 AM   #7
Highsteel
Chasin' the Dream
Highsteel's Avatar
True pcmcobra, I was not 'belittled' as nothing was said against me.
I apologize to you, Longhorn Man, for insinuating that you belittled me, as you most obviously did not say anything derogatory against me.
Jerry
