04-06-2008, 07:34 PM | #1 |
if only I could weld....
Now don't laugh....
I said don't laugh. Now cut it out. Time to go do the other one.
- Greg |
04-06-2008, 07:43 PM | #2 |
Re: if only I could weld....
That looks pretty good if your just getting started --- much better than my first welding project
Are you retired too? Nonsense! I'm in my prime |
04-06-2008, 08:38 PM | #3 | |
Not too bad I suppose for exhaust pieces. Now I just need some time to go over to the shop and fit up the X-pipe.
- Greg |
04-06-2008, 11:35 PM | #4 |
It Is What It Is,,,,
Looks good to me. Just as it doesn't leak,, its all good to go man.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
04-07-2008, 12:06 AM | #5 |
Well done man!!
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
04-07-2008, 12:11 AM | #6 |
I don't think those welds look bad at all, better than I can do. I can grind very good though!
04-07-2008, 04:40 AM | #7 |
Thanks for the kudos. Gets me inspired to do more.
Here is the Summit 3" X-pipe and Hooker AeroChamber mufflers I will be using. Here are the cutouts I welded this morning bolted to the headers with the front part of the X-pipe in place. I need to trim a couple inches off the front 45's to bring the X closer to the collector flange. The mufflers I have are like 22" long. It's going to be a tight sqeeze to get them tucked in front of the axle.
- Greg Last edited by 454HO; 04-07-2008 at 04:41 AM. |
04-07-2008, 07:06 AM | #8 |
The looks of the bead mean nothing! The only importance is the strength, and a solid weld that doesn't leak! Let me tell you, submerged arc with a stick welder looks ugly! It will hold more than any other weld out there!
04-08-2008, 04:52 AM | #9 |
those welds look pretty good man...like a few other people have said...its not the looks of the weld that matter (especially since they are under the truck) its that they don't leak or break on ya that does
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
04-08-2008, 05:00 AM | #10 |
Sb 400 club
Not bad welds if they seal who cares it is exhaust...
I like the set up I plan too add cut outs some day
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
