Old 04-06-2008, 09:57 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
How does the stock AC center vent mount?
I was looking through the boxes for my Vintage air setup and started test fitting some stuff. I had welded in an AC dash (bare) and now that I'm fitting things up from Vintage I noticed the chrome center vent I got from them mounts with studs to the provided plenum. However where the stock AC vent hole is in my dash, I have 4 small screw holes at each corner? Was there some kind of additional plate that screwed into the dash, then the vent into the plenum???
Does anyone have pictures of how a stock AC vent mounts or have info? Thanks!!
JC
jcfoote60 is offline   Reply With Quote
Old 04-06-2008, 10:26 PM   #2
Sammy
Re: How does the stock AC center vent mount?
The inner black plastic piece has two holes that come from the studs mounted on the grille item hoipefully you can tell from these two pics. No studs on mine but believe you can make out what I am referring to. Hopefully this answers your question.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-06-2008, 10:29 PM   #3
Sammy
Anytime your at the junk yard retreiving that center vent always get those studs, I don't believe anyone repos them.
Old 04-07-2008, 04:19 PM   #4
jcfoote60
Active Member
jcfoote60's Avatar
yep that answers my question......now I get to weld up the screw holes the PO hogged in around the vent cutout!!! Lord only knows what the PO was thinking or trying to do. Anyway thanks for the replies....now off to fix my dash!!
