Old 04-06-2008, 10:38 PM   #1
EyeH8the24
EyeH8the24's Avatar
gear ratio ?
i have a 87 lwb with a 350 and 350 trans,any guess as to what the rear gear would be with out pulling the diff cover ? the numbers stamped into the axle tube is BR3 G175
EyeH8the24 is offline   Reply With Quote
Old 04-07-2008, 05:28 PM   #2
EyeH8the24
EyeH8the24's Avatar
Re: gear ratio ?
anyone?
Old 04-07-2008, 08:33 PM   #3
larrystone
larrystone's Avatar
Re: gear ratio ?
The gear ratio for my 1986 is right on the sticker with the options in the glove box.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 04-07-2008, 09:19 PM   #4
LONGHAIR
Re: gear ratio ?
I have almost answered this twice...
It's very hard to say...3.08
It could be as high as 2.73 or as low as 3.54 or 3.73
But you are talking about a 21 year old truck, could be anything.
LONGHAIR is offline   Reply With Quote
Old 04-08-2008, 03:57 AM   #5
slugish
Slugish
Wink Re: gear ratio ?
most all 3 speeds during these years came with came with a 273 ratio unless it had a h d pkg. (7 leafs in rear & a 1 1/4 in rotor ) -3/4 or 1 ton .
Iwas told my 84 had a 2.56 ratio even . when the trans man had it out & counted the teeth . It is a swb & came stock with a 305 / 350 trans. Hope this helps
slugish is offline   Reply With Quote
Old 04-08-2008, 04:30 AM   #6
EyeH8the24
EyeH8the24's Avatar
Re: gear ratio ?
pulled the cover today...its a 2.73....the cab is trashed .so i had no info on anything for the truck ...thanks guys...
