Old 04-07-2008, 03:08 AM   #1
1971 K10 shortbox
Glovebox Trim Questions
Can anyone tell me how to remove the emblem and the chrome trim from a Super glove box door. The wood grain needs to be replaced, so I am not worried about damageing that, but I dont want to ruin the chrome trim or the emblem.
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
1971 K10 shortbox is offline   Reply With Quote
Old 04-07-2008, 05:01 AM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Glovebox Trim Questions
The emblem has three little pop in clips on three studs. I would gently start prying it with something flat at all corners and in between, around and around. It should eventually come out leaving the clips behind in the door to remove afterwards.
The wood grain piece is really glued on there. I take like a really wide flat putty knife/spreader and start working my way around it. You might have to use like a rubber hammer to do some taping on the handle on the blade. Be careful not dent it though, from the back side.
That is how I have done it several times. Someone probably has a better way to do.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-07-2008, 05:18 AM   #3
sameyrasmea72
Just for clearification you won't be able to remove the woodgrain from the trim if it is a factory one. Not by pealing it off anyway.
72 Cheyenne Super
Old 04-07-2008, 05:22 AM   #4
1971 K10 shortbox
I was just going to put new wood grain overtop of the old.
I tried using a butter knife to remove the emblem, worked like a Charm, barrel clips and everything poped right off.
So next I used the magic tool, aka butter knife, to slide in behind the chrome trim, slid it around the edge, little tough in spots but not bad. Presto, I have it all apart.
Thanks for the help.
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
Old 04-07-2008, 06:56 AM   #5
jhow66
jhow66's Avatar
Decal remover will take it off. Can buy it at parts store.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
