04-07-2008, 05:50 AM | #1 |
LED tailights
Clasic Parts, https://www.classicparts.com/searchprods.asp has LED tailights, both clear and red. The price seems reasonable.
(1967-72) LED Taillamp Lens-Fleetside/Blazer-Reproduction Product : 49-236L Price : $29.95
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
04-07-2008, 05:57 AM | #2 |
Re: LED tailights
Wow, that is cheap for LED's. I paid $260 For LED taillights for my Tahoe, that is a good deal, i would get the red, it is a more original look than the Clear, it would blend in too much with the reverse lights.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-07-2008, 06:02 AM | #3 |
67-72 Addict!
Re: LED tailights
That's $29.95 each!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-07-2008, 06:04 AM | #4 |
Re: LED tailights
Still is $200 cheaper than the taillights for my tahoe, but then again, they are much simpler, too.
04-07-2008, 03:54 PM | #5 |
Old member
Re: LED tailights
Those LED'S are very big and only cover half the lens. I have seen them and even bought a set at the Myrtle Beach car show for a friends truck. Personally I didn't like them but...
I haven't ever seen the clear ones. Has anybody got a set hooked up with pictures for us.
04-07-2008, 05:11 PM | #6 |
its all about the +6 inches
Re: LED tailights
the clear ones have probably been discontinued.
I think the original maker of these used to be a board member. (not the guy who sells the real expensive ones either) If i recall right, he said that when he went for a DOT aproval, they told him not to light up the lower reflective portion. |
04-08-2008, 04:23 AM | #7 |
Re: LED tailights
OK, I ordered the clear LED lights, total cost with shipping was $67.85. They should be here by Wednesday. I'll keep you posted. The pic looks like the bottom portion is not LED, it is the reflector. It looks like there are 5 rows with 4 LED's per row from the top of the reflector to the top of the lens. That should be plenty bright. When I made the original post, I had just received the notice from them that they were available, so we will see.
04-08-2008, 04:46 AM | #8 |
Re: LED tailights
watching too
Trueman |
04-08-2008, 04:54 AM | #9 |
Tasty Cakes!
Re: LED tailights
Ya I've kinda been wondering about these too. I like the other ones I've seen, but these are sooo much cheaper. Keep us updated!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
04-08-2008, 05:20 AM | #10 |
Re: LED tailights
bin thinking bout goin clear, maybe il take the clear leds. please post pics wen u got them in.
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
04-08-2008, 05:38 AM | #11 |
Just loves his truck.
Re: LED tailights
Gold 1969 c10 LWB--350 gm crate motor 30"muds on the back...with aluminum rims with black and red Chevy bowtie center caps that look awesome! EAGLE SCOUT FTW!!! |
04-08-2008, 05:44 AM | #12 |
Re: LED tailights
those look just like the ones I got from Musclerodz he is a vendor for the site.
They are very bright, I have the clear ones. Several at the board meet saw them. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" Last edited by Custom 68; 04-08-2008 at 10:23 PM. |
04-08-2008, 05:47 AM | #13 |
Re: LED tailights
here is one from a while back.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-08-2008, 03:40 PM | #14 |
Tot Roddin'
Re: LED tailights
Different... but cool!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-08-2008, 04:40 PM | #15 |
Re: LED tailights
Does anyone have a blue dot lens (I know they're illegal in most states) with an LED panel behind the lens (not part of the lens)? I know where to get the lenses and the panels, just wondering if anyone else has done that...
And yes, that's a great price! I paid $75 for my stepside LED's. They're just like those, the LED's are part of the lens. They work GREAT!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-08-2008 at 04:42 PM. |
04-08-2008, 04:41 PM | #16 |
Re: LED tailights
I am running a set of the red. The lights are really bright and the reflectors on the bottom are great. I tried to take some pictures at night and I had to turn off the flash because of the reflectors. I did not buy them because LEDs are cool but because I wanted the cars behind me to know when I was applying the brakes.
Hook'em |
04-08-2008, 04:43 PM | #17 | |
Re: LED tailights
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-08-2008, 05:07 PM | #18 | |
Insert Title Here
Re: LED tailights
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 04-08-2008 at 05:09 PM. |
04-08-2008, 05:10 PM | #19 |
Insert Title Here
Re: LED tailights
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
04-08-2008, 05:21 PM | #20 |
Trucks N Tranzams
Re: LED tailights
I have a set of these as well (red from musclerodz) and they are very bright.
I used chrome paint for the inside of my buckets. It doesn't make a difference with the LEDs. but it sure helps with the incandecents though
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 04-08-2008 at 05:23 PM. |
04-08-2008, 05:45 PM | #21 |
Re: LED tailights
That's just what I want!
Where did you get the lenses? Or did you drill a set of stock lenses (I'm afraid of drilling a new set of lenses.) Is it all one piece, or is it a lens with an LED panel behind it?
04-08-2008, 05:52 PM | #22 |
Insert Title Here
Re: LED tailights
The lense is just the stock one with a blue dot, the LED's are actually all white not red, they are for my front my markers, but i just put them in there to see how they looked
I got them from this guy http://67-72chevytrucks.com/vboard/member.php?u=9723 heres my threads http://www.67-72chevytrucks.com/vboa...d.php?t=280668 http://www.67-72chevytrucks.com/vboa...d.php?t=280477
04-08-2008, 06:22 PM | #23 |
Re: LED tailights
We still sell the red, but not the clear, they are not DOT approved. They are on our website. www.musclerodz.com
Mike Redpath |
04-12-2008, 03:14 AM | #24 |
Re: LED tailights
The lights came in today. Here are the pics. They look brighter in person than the photos show. It was well worth the money.
04-12-2008, 03:24 AM | #25 |
Re: LED tailights
a few more pics
