Old 04-07-2008, 06:29 AM   #1
prg machine
prg machine's Avatar
4x4 transfer case shift decal location.
I have seen the transfer case shift pattern on the glove box and my 69 had it on the cieling ( inside of roof_) ..... what is correct? and where?
Also how about the locking hub sticker?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 04-07-2008, 06:34 AM   #2
ed2552
ed2552's Avatar
Re: 4x4 transfer case shift decal location.
Locking hub sticker on my 67 is on the glove box door (i think), and the pattern is on the passenger roof (for sure), 69 may be different
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-07-2008, 07:17 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I think it just depends on the factory where they put the sticker. Both are correct, but for you, if it was between the two visors, I would put it back there. I believe those two spots to be correct though. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-07-2008, 02:59 PM   #4
jrdv
jrdv's Avatar
This is on my 69 K10.
jrdv is offline   Reply With Quote
Old 04-07-2008, 03:02 PM   #5
Don`t put those stickers on there!!It will increase the value to at least double!J/K!!!!!Just tryin`to make light of your situation.I`d have to agree with Trevor.Location varied and I`d go with where they were.
Old 04-07-2008, 08:08 PM   #6
prg machine
I might wait till a future date then if I get your drift!!!!???
383 .040 over
Old 04-08-2008, 08:42 PM   #7
1969K10
1969K10's Avatar
any chance the location had to do with the type of X-fer? the pic shown is the shift pattern for a T-221. I've never seen a truck with the shift pattern sticker in it, but that's not saying much.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-08-2008, 08:51 PM   #8
71blksuper4x4
SWB 4x4 Collector
I don't know if there is really a true answer to this, but I would believe more on what factory these trucks came from as a possibility. I have a 1970 chevelle as well, and even like buildsheets ended up in about the same spots from the same plant, but were way different in other plant locations, even not even putting them in. This leads me to believe that it just depended on that shift's worker who put the stickers in that location but at another plant they would put them in a different spot. I know that there are shift pattern decals with np205's as well, but most didn't come with them because of the shift pattern on the knob unlike the 67-68-possibly 69'? Trevor
TREVOR
Old 04-08-2008, 10:02 PM   #9
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
My 68 has a rockwell transfercase and the sticker is between the sunvisors.
Jason
jay_shy is offline   Reply With Quote
