Old 04-07-2008, 04:36 PM   #1
stumped
Raw gas smell
I have a 78 GMC 1 Ton Dually with dual gas tanks. All tanks, lines, fuel pump and componentes are new, but have a strong raw gas smell in the cab while driving. (Not when idling or parked)
Engine is a small block 400 with a holley carb and holley headers.
All rubber lines from the tanks to the carb are new.
Thought that it might be the vents at the sending unit, so I plugged it, but it still smells. The only thing not new are the sending units.
Thanks for any help
stumped is offline   Reply With Quote
Old 04-08-2008, 12:28 AM   #2
Prong
Re: Raw gas smell
Do you have vapor canisters? On my 79, if I fill the R tank too full when it's warmer out, the vapors condense in that canister and I get the same smell you're talking about.
Prong is offline   Reply With Quote
Old 04-08-2008, 04:52 AM   #3
stepside454
stepside454's Avatar
Re: Raw gas smell
try driving it with the fill cap loose...or off & see if it still stinks.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 04-09-2008, 05:20 AM   #4
knightlife
Dark Heart Motorsports
knightlife's Avatar
Re: Raw gas smell
check the lines running to your mechanical fuel pump on the block... it could be the feed line from the tank to the pump. common problem
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
