Old 04-07-2008, 05:16 PM   #1
javadoc
Hey Watch this...
javadoc's Avatar
Starter Noise Question (is it DONE?)
I had to take my starter out to squeeze the headers onto my truck. Then, I put it back in. Now, when I start the truck, the starter is making this loud whining noise while the engine cranks. I don't know if it's now dead for some reason, or I have something misaligned. There's only two bolts holding the starter in place, so I don't think I have it in wrong. Any suggestions?
Thanks in advance,
Scott
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 04-07-2008, 05:49 PM   #2
PA66C20
PA66C20's Avatar
Re: Starter Noise Question (is it DONE?)
Scott,
How can you tell if its a boy or a girl?
Guess we'll have to roll it over to find out!
PA66C20 is offline   Reply With Quote
Old 04-07-2008, 05:51 PM   #3
PA66C20
PA66C20's Avatar
Scott,
I have a 66, so I do not know if it is the same bolt pattern. My starter has 3 bolts on it, so you might want to check a little closer. Also you might have to shim your starter to get it to align with the gears correctly. Just a thought?
Shawn
Old 04-07-2008, 06:20 PM   #4
salazar44
65 - Chevy C10
salazar44's Avatar
This is exactly the same problem I have. I think the starter gear is getting jammed in the flywheel and it cant turn. Sometimes mine gets stuck and wont retract back into the starter either.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 04-07-2008, 06:46 PM   #5
javadoc
Hey Watch this...
javadoc's Avatar
Thx for the replies. Shawn, I don't think I'm missing a bolt though. Shims.. maybe that's the trick though.
