Old 04-07-2008, 08:55 PM   #1
Silvius
Silvius's Avatar
Intake manifold swap-- how much labor?
Hello again
About how many hours should I expect for an intake manifold swap along with the labor for a new carb install? I won't be doing it myself; no time. I have the parts already (the shop I am working with doesn't have a problem with that).
I have:
New Edelbrock Performer Intake Manifold
Intake gasket set and new intake bolts
New Edelbrock Performer Carb with vaccuum secondary and electric choke
The stock intake manifold and tired Quadrajet will be replaced with the Edelbrock goodies listed above. If other items are needed like new coolant and some labor involving the distributor are involved, that should be figured in. I'll be supplying any coolant or gaskets.
Also, the tranny is leaking so I am getting the main seal replaced. Again, parts provided.
How much labor time wise?
1972 Cheyenne Super
Silvius is offline   Reply With Quote
Old 04-07-2008, 09:03 PM   #2
Silvius
Silvius's Avatar
Re: Intake manifold swap-- how much labor?
1972 Cheyenne Super
Old 04-07-2008, 09:06 PM   #3
LONGHAIR
Do you mean like "flat-rate"? It would be hard to guess. It is not really like a dealership flat-rate type of a thing. You are not swapping an identical item, like you would with a water pump or something. You are talking about at least a little fabrication/adapting. I guess it depends on the mechanic.
Which transmission? Which seal, input or output?
LONGHAIR is offline   Reply With Quote
Old 04-07-2008, 09:09 PM   #4
HoupPhotography
Are you asking so you can plan your day accordingly (doing it yourself) or are you taking it to a mechanic?
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-07-2008, 09:16 PM   #5
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Flat rate to do the intake gaskets is about 2.5 hours. Additional time to install new parts, modifications and running down "unforseen" extras will add to that. Things like throttle linkage, sender ports & accessory bolt hole differences on a new intake, and lack of vaccum ports can be a pain. But yours should be pretty simple to get done- so I wouldn't accept a huge bill when it's done without details of the extra work they encountered.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 04-07-2008, 10:02 PM   #6
Silvius
Silvius's Avatar
Good point about it not being a standard replacement as there are aftermarket parts involved. It sounds like for the intake manifold part and the associated work 3-5 hours wouldn't be unreasonable.
Longhair said "Which transmission? Which seal, input or output?"
I don't know. It is the one that is more labor intensive if I remember correctly. I haven't got that part yet. Would the labor time be about the same....I was told one took longer than the other.
1972 Cheyenne Super
Old 04-07-2008, 10:07 PM   #7
streetstar
streetstar's Avatar
5 hours for everything, unless the tranny has to be pulled.
That is working at a pretty quick pace, but not setting the world on fire
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-07-2008, 10:16 PM   #8
Silvius
Silvius's Avatar
Just checked; tranny will have to be pulled to replace that seal.
How much more time for that, best guess?
1972 Cheyenne Super
Old 04-07-2008, 10:38 PM   #9
streetstar
streetstar's Avatar
3 extra hours -- if it is a shop equipped with a lift.
If it is just an Okie with a couple of jackstands, a floorjack and a case of Budweiser, i'd count on 2 weeks -- LOL
Old 04-07-2008, 10:46 PM   #10
Silvius
Silvius's Avatar
Good thing I'm not in too much of a hurry....
1972 Cheyenne Super
