Old 04-07-2008, 10:53 PM   #1
Silvius
Silvius's Avatar
Stubborn column shift
The Cheyenne is rather uncooperative when it comes to shifting it in and out of gear, even if it isn't parked on a grade. You have to muscle it in and out of gear (3 speed auto column shift).
What does it take to fix? Are there some bearings to replace? Is it an all-day affair?
I searched the board but I guess I didn't put in the right phrasing because this must come up quite a bit.
1972 Cheyenne Super
Silvius is offline   Reply With Quote
Old 04-07-2008, 11:11 PM   #2
Alex Hayley
Re: Stubborn column shift
Having just taken a column apart, I have an idea of the moving parts(very few) in the column. Can you determine if the friction is in the column or the shift linkage between the column and the transmission?
Alex Hayley is offline   Reply With Quote
Old 04-07-2008, 11:13 PM   #3
Silvius
Silvius's Avatar
Seems to be in the column.
1972 Cheyenne Super
Old 04-07-2008, 11:49 PM   #4
Wrenchbender Ret
Remove the pin holding the gearshift lever & pull out the lever. Spray some lube like WD-40 inside the hole up around the upper part. Put the lever back in & try it. If that doesn,t get it spray some in the opening at the bottom of the column where the lever comes out that goes to the trans. There are 3 small bolts above that area. You can take the center one out & spray in there.
Wrenchbender Ret is offline   Reply With Quote
Old 04-08-2008, 02:29 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Good advice.
This is what I did to mine when it wasn't shifting right and it loosened it right up... Works great now.
LockDoc
Leon
Old 04-08-2008, 02:58 AM   #6
cdowns
cdowns's Avatar
and while you have the spray lubrucant in your hand you might search for other moving parts that havent been lubricated in 40years
Old 04-08-2008, 04:42 AM   #7
corn
Are the old GM trucks at all like the old fords with cab supports? I know a friend of mine had an old ford that wouldnt shift & his front cab supports were rusty & puting pressure on the column. Did you disconnect the linkage to make sure the bind is in the column?
corn is offline   Reply With Quote
Old 04-09-2008, 01:57 AM   #8
Joesjunk
Joesjunk's Avatar
I have seen this problem several times, and the above advice will work, you might not even have to remove the shifter if you want to just try to use the spray nozzle to get next to the shift arm. Good luck!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is online now   Reply With Quote
Old 04-11-2008, 02:27 AM   #9
Silvius
Silvius's Avatar
Good stuff guys thanks
1972 Cheyenne Super
Old 05-08-2008, 02:28 AM   #10
Silvius
Silvius's Avatar
I finally got a chance to have this done. It works great now. Thanks Wrenchbender and everyone else who posted.
1972 Cheyenne Super
