Sierra Grande Club
column bearing question
I'm looking at getting a replacement bearing and found this one on Classic Heartbeat
My question is there supposed to be a spring on the inside? or just on the outside? I take it that I should be able to pop out my old bearing and reuse the holder? (I also found several places that have just the bearings. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: column bearing question
I replaced them both, it's not that much more money. The bearing should slide right in. And I'm not aware of any spring in there. I would get a shop manual if you don't have one; they have got a couple of pretty good pictures of the column expanded. Either that, or an LMC parts catalog.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
The spring goes just above the intermediate shaft coupler: there's a washer on one side, and the bearing on the other. Here's an illustration:
Sierra Grande Club
Thanks Dan. That's how I understood it to go, but was wondering since I seen the one on Classic Heartbeat showing the spring.
You never know what was changed by the PO. s/t
