Old 04-08-2008, 07:42 AM   #1
my70chevyc10
my70chevyc10's Avatar
Talking new alt and reg
I just instaled a new alternator and regulator to night and i want to know how much volts it should be charging. just the battery reads 12.5 to 13 volts but when i start the truck it reads 15 to 16 volts charging and i want to know if thats to high.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 04-08-2008, 09:12 AM   #2
Jerdog
Re: new alt and reg
The voltage is too high, it should be about 14 to 14.3. What are you using to measure the voltage? Why did you swap out the regulator and the alternator in the first place?
jerdog
Jerdog is offline   Reply With Quote
Old 04-08-2008, 12:28 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: new alt and reg
in all reality, yoiu should consider getting a unit with the internal regulator. There's about eleventy billion threads here showing how ti do it, but the regulator in the later model altenators are simply better, and there's a higher amp rating, and it gives way more power at low RPMS.
Old 04-08-2008, 02:16 PM   #4
truckdude239
truckdude239's Avatar
Re: new alt and reg
i like t see between 14-15 volt here check out this swap
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-08-2008, 02:58 PM   #5
70GMCer
70GMCer's Avatar
Re: new alt and reg
I like that..... "eleventy billion".....I guess that means "a lot" huh?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-08-2008, 03:22 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: new alt and reg
Great link!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-08-2008, 10:53 PM   #7
Longhorn Man
Re: new alt and reg
yep... a whole bunch.
Old 04-08-2008, 11:45 PM   #8
cdowns
cdowns's Avatar
Re: new alt and reg
you should also make sure you have a good ground from the rad support to the frame rail for proper operation of the regulator
Old 04-09-2008, 02:53 AM   #9
Andy4639
Old member
Andy4639's Avatar
Re: new alt and reg
When you check for the reading it should be after it's warmed up. At idle it should read around 12 1/2 to 13 volts. At fast idle around 14. I think it's 2500 RPM'S.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-09-2008, 03:42 AM   #10
68caliRat
Need a bigger hammer..
Re: new alt and reg
Mine reads 15.25 volts at about 2000 RPMs, always has..
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
