04-08-2008, 07:44 PM | #1 |
Active Member
Impossible hatch repair?
Well, i finally decided to see if i can even fix my hatch today. Figured i had nothing to lose at it's present state. This will kind of be slow going since i have never done fiberglass repair and have limited time to work on it, but i am willing to give it a shot.
Here is what i have to start out with. I then seperated it with a putty knife also sharpened on one side. Total time to do this was about an hr. I did do some new damage taking it apart, but for the most part it did seperate fairly well.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) Last edited by EFI70Blazer; 04-08-2008 at 07:53 PM. |
04-08-2008, 07:47 PM | #2 |
Active Member
Re: Impossible hatch repair?
I plan on foam filling the entire hatch before i glue it back together to hopefully give it more strength and stability
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
04-08-2008, 09:04 PM | #3 |
You can do it! My hatch looked about like that once I got the globs of kitty hair off the PO put on it. Here is how I went about it http://67-72chevytrucks.com/vboard/s...d.php?t=264025. I didn't post many pics of the after but can take some more if that'll help you. Just remember that it's useless like it sits now so you can't really screw it up only make it better!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
04-08-2008, 10:52 PM | #4 |
Active Member
If you want to take some after pics that would be great. I need to get some measurements where the latch pieces go, because mine does not have those parts at all and i dont have the pieces to put back in either.
04-09-2008, 01:11 AM | #5 |
i had no idea they separated like that! I'm watching...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
04-09-2008, 01:37 AM | #6 |
Had no idea either, should make the repair easier. Thanks for the info! I'll keep watching....J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-09-2008, 07:21 AM | #7 |
Question....
Can you get the inside plates out with out spliting the hatch. Will the plate where the t-handle mounts slide out the side when the latches are removed. |
04-11-2008, 03:22 AM | #8 |
Active Member
I dont see any way they can come out without splitting the hatch. You would also have to remove the rivets that hold the metal pieces in place.
04-11-2008, 03:50 AM | #9 |
go cyclones
Keep us all posted, I am interested in doing some fiberglass work this summer if it isn't too difficult
04-11-2008, 09:10 AM | #10 |
That is what I figured. One hatch I have is perfect on the outside, and rusty on the inside. The second hatch is cracked in multiple places on the outside, but perfect on the inside. Maybe I will just split them both and frankenstien one together.
04-11-2008, 05:24 PM | #11 |
Mine needs some work too. I will be watching to see how it goes and to get some tips before doing mine. Good luck with the project.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
04-11-2008, 05:36 PM | #12 |
What if.... you cut an access hole, since you have to do fibreglas work any way, jat...J.
04-11-2008, 08:24 PM | #13 |
might sound stupid but if you are foam filling it any way (wich i think is an awesome idea) how about putting in a metal or wood frame around it on the inside and then fill it with foam it will rattle until the foam sets but wouldnt that really stiffen it up
it would be like using rebar on concrete kinda reinforce the foam i have also considered replacing the side struts with gas charged struts off of a late model something or other they make them in all sizes and stroke just a thought i need to do this to my hatch also so i will be watching this thread closely just puttin my 2 cents on some thoughts i have had for mine when i get ready to tackle |
04-12-2008, 03:58 AM | #14 | |
Active Member
You could probably do that, just cut a small hole for the end pieces, but the part over the hatch handle would take a pretty big hole.
04-13-2008, 06:50 AM | #15 |
Global warming is a myth
Subscribed
IMHO, I'd go and check out a few topper hatches & how they latch closed. I have always thought that the o.e. style latches were a little fussy & problematic. I'd prefer, personally, that they be a bit simpler. All that to say this. Since you basically have a blank canvas to do with whatever you'd like, why not make it work exactly how you'd like it to. Simplicity is priority, few but effective parts with little to wear out, & easy to adjust & maintain. BTW - when I first got my blazer, the handle didn't lock. I looked high & low for a replacement key or for a locksmith who could work this out for me. Nothing worked because of the condition of the handle. I did however find that a regular garage door handle that you could & still can get from home depot or lowes fits into the square hole for the rod pivot perfectly, you just have to trim the length of the shank on the handle. For around 10 bucks you can have a new & shiny hatch handle that looks VERY close to OE. Here's a link - https://www.hardwareworld.com Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
04-14-2008, 03:01 PM | #16 |
Back in the sticks
Thats a great way to do it! I had started on mine with the dremel and a cut off wheel to get mine split, but haven't gotten it finished yet. Thanks for the inspiration!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-14-2008, 06:58 PM | #17 |
Active Member
Found this little writeup and thought i would try it this way.
http://www.boatus.com/boattech/casey/17.htm
04-15-2008, 05:29 AM | #18 |
Active Member
I did a little bit of work on the outer skin for my hatch today. I sanded the entire back side down with 36 grit sand paper and tapered the spots where cracks were. For now i just coated the cracked area's and the most of the area's where it was entirely through. After i sand this layer down i will fill them in a little more and add another couple of layers to the entire back side to strengthen it up some.
This is what has been taking up my time lately. This is last fall This is now I am going to put a shop in this summer, so i am having to remove all the tree's and other junk back there. I just need to dig up the remaining stumps and also remove the one big tree left. So far i am up to 15 tree's that i have removed.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) Last edited by EFI70Blazer; 04-15-2008 at 05:40 AM. |
04-17-2008, 07:22 AM | #19 |
Future TOTM Winner
Good luck with the shop. I am trying to finish up a 3 car garage that I started back in December that STILL isn't finished, but should be soon.
As far as the hatch goes, I am really interested in the foam filling idea. The hatch seams to be a weak spot on every blazer and I think this would be a nice way to give it some strength and still remail relatively light weight. I can't wait to see what you do. Keep up the good work. I have two hatches that I MIGHT get around to working on this year...I hope.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
06-15-2008, 03:25 PM | #20 |
Any progress with the shop and or hatch repair?
06-19-2008, 03:22 PM | #21 |
Cochino_Racing_909
Cool keep the play by play pics coming.
06-21-2008, 11:08 PM | #22 |
Active Member
Sorry, no more progress yet. Been ripping out fence and cleaning out all the stumps. Hopefully will have a shop going in sometime in July.
06-22-2008, 11:51 PM | #23 |
You do know you can buy a brand new hatch for $400-$500 bucks right?
06-23-2008, 01:25 AM | #24 | |
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's Last edited by BUDDY; 06-28-2008 at 09:49 PM. Reason: spell check |
06-23-2008, 09:18 AM | #25 |
Chill out, I was just making sure he knows, some people don't.
