Old 04-08-2008, 09:06 PM   #1
chevychase
chevychase's Avatar
Question 17x9.5 with 5.5 Backspacing on 4/6 Drop?
I did a bunch of searching first, so please don't beat me up too bad! I don't have a lot of posts becuase I always search and usually find my own answers thanks to this awesome forum!
Question: '67 Automatic Truck Lowered 4/6 with '71 5 Lug Front and '71 5 lug Rear End. Wheels are 17 x 9.5 Wheels on all 4 Corners with 5.5" Backspacing. No tires yet, so I'm open to sizes. I'd appreciate ANY feedback if these rims will work and/or tire sizes. Thanks in advance guys!
chevychase is offline   Reply With Quote
Old 04-08-2008, 09:16 PM   #2
whatnow123
whatnow123's Avatar
Re: 17x9.5 with 5.5 Backspacing on 4/6 Drop?
Welcome to the board!
Anyway, I don't know about the front, but with a 67 narrow rear, you won't be able to install the rear wheels due to interference of the bed. I have 4.5 backspacing and have less than 1/2 inch between the tire and the bed.
Not to mention, with that much backspacing, the wheels are going to be really set inward on the truck.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-08-2008, 09:20 PM   #3
chevychase
chevychase's Avatar
Thanks for the reply and the welcome! I forgot to mention I have the '71 5 lug front disc swap with the '71 rear swap as well. Will this help any? I updaed my original post.
Old 04-08-2008, 10:28 PM   #4
SactoJim
SactoJim's Avatar
I think that is too much back spacing.....here's mine (18X9.5 with 4.5" BS).
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 04-08-2008, 10:57 PM   #5
whatnow123
whatnow123's Avatar
I'd take some careful measurements on what you have on there now and compare that to how it's going to fit. With the wider rearend you probably are going to be real close to the bed, but could probably do it.
Here is a photo of mine. I've got the narrower rear and the rim is 17x10 with 4.5 inchs of backspacing and a 285 tire.
Build thread:
Old 04-08-2008, 11:18 PM   #6
chevychase
chevychase's Avatar
Thanks SactoJim and whatnow for the pics, both sweet trucks! The rims are over 2 hours away and truck is under construction. They are Torque Thrust II's that I love. Would a 1" spacer or so solve any of these issues? BTW, I have a SWB Fleetside bed.
Old 04-08-2008, 11:53 PM   #7
chevychase
chevychase's Avatar
Would a tub in the rear help? That would be cool anyway!
Old 04-09-2008, 12:01 AM   #8
SactoJim
SactoJim's Avatar
Ultimately it's always best to measure for yourself as "whatnow123" said. Put the rear of the truck on jackstands on level ground (jackstand under axle) with the rear wheels off and tape a piece of string with a nut tied to the end at the top center of your wheel well opening. Use a straight edge on the drum mounting face and measure away. This will get you close to what you need. There's plenty of info on the web in regards to tire sizes with section widths being one of the key points you would be looking at.
If you already have wheels lined up and they aren't your preferred backspacing, I would say spacers are fine as long as your aren't trying to make up too much......I don't think I'd wanna go more than an inch.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 04-09-2008, 12:20 AM   #9
68Stepbed
68Stepbed's Avatar
I had some 17x9.5 on the rear of my stepside before. I had 275/60/17's mounted on them. They did rub just a tad on the inner bedside. I had to buy an adjustable panhard bar. If you went with a lower profile like a 275/50/17, you shouldn't have any problems. The 60 series tires had alot of balloon to them. I don't think the front will be alot of problem either. My rear tires fit on the front better than they did in the rear.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-09-2008, 12:24 AM   #10
chevychase
chevychase's Avatar
I wish my truck was in the condition where I could measure as described.
Bed sides are at Body shop and who knows when they'll be ready. Worst case, could I do a little tub in the wheels tubs for clearance? How about the fronts?
Old 04-09-2008, 12:32 AM   #11
chevychase
chevychase's Avatar
Sounds encouraging! I already have 2 adj. panhard bars. I have no problem rolling with a lower pro tire like suggested. Do you think a minor tub or roll would have solved the rubbing issues you had in the back? Thanks to all so far!
Old 04-09-2008, 02:54 PM   #12
68Stepbed
68Stepbed's Avatar
Yes a small tub would work perfect, but if you go with a lower profile tire, I don't think you will need it. The only time mine rubbed was when making hard turns. It didn't rub all the time. It was also only the very middle of the ballooned section of the tire that rubbed. I took the wheels off once to see how bad it was, and it barely rubbed the lettering down.
Matt
Old 04-09-2008, 09:51 PM   #13
Mondo
Mondo's Avatar
better to have a little too much B/S as you can add spacers.... too little
Most guys say 4 to 4 1/2 B/S in front (I've been reading up too)
I must have a narrow rear end on my 67 (though it's 5 bolt) as 1 inch spacers bring the tires out about the same width as the front
Mondo is offline   Reply With Quote
Old 04-09-2008, 10:06 PM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-10-2008, 03:30 AM   #15
Fastfun
Fastfun's Avatar
I have 17x8.5 on front and 17 x 9.5 on the back but I would have to check on the back spacing. I think it might be 4.5
Fastfun is offline   Reply With Quote
Old 04-10-2008, 04:21 AM   #16
see ten
WTB this ad
see ten's Avatar
I'm running a 3.5"/6" drop. Wheels are 17x9.5 with 4.75 of BS out back. The fronts are 17x8 with 4" of BS.
see ten is offline   Reply With Quote
