Old 04-08-2008, 11:31 PM   #1
Texas1971
Remove and replace dizzy cap to start everytime?
In order to get it to start I have to remove the cap leave it in the sun for a while put it back on ... then it fires right up. Over and over it will start/stop. But if i leave it set for a couple of days it will go into "no spark" mode. Is that a crack or something else. New module BTW>
Thanks for yourr tips.............scott
Texas1971 is offline   Reply With Quote
Old 04-08-2008, 11:54 PM   #2
lowriden58
lowriden58's Avatar
Re: Remove and replace dizzy cap to start everytime?
sounds like your gettin moisture in there somehow i would replace the cap/rotor and see if that cures it. is this a HEI?
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 04-09-2008, 12:16 AM   #3
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
ditto
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 04-09-2008, 04:04 AM   #4
pumpkin
pumpkin's Avatar
The older point style distributor caps were made out of a bakelight sort of stuff, and the would get waterlogged,,, sort of. Sounds like you need a new cap and rottor.
pumpkin is offline   Reply With Quote
