Old 04-09-2008, 01:12 AM   #1
sandhillmike
New guy, cab fit question
I just picked up my first Chevy project. I have done several Fords and Jeeps.
I have a 1955 1st series 3600 frame and running gear. frame has already been blasted, painted and assembled and engine/trans is in excellent condition. My question concerns cab compatibility. From looking at a couple of catalogs it seems like I could use any cab from 47-54. Is this right or will I run into fit and fab problems with the earlier cabs/front clips?
sandhillmike is offline   Reply With Quote
Old 04-09-2008, 01:47 AM   #2
playinsafe44
Re: New guy, cab fit question
if it really is a 55 first series frame then it should fit the later style cab mounts, but you could mount any cab from 47-55. im not sure when they changed the rear cab mounts, but i think it was from 50-55 first series. the early rear cab mount is a single center mount. but it wouldnt be hard to fab something up to adapt either style of rear mount. thats the only difference that i know of.
playinsafe44 is offline   Reply With Quote
Old 04-10-2008, 08:39 PM   #3
sandhillmike
Re: New guy, cab fit question w/pics
Thanks, now just have to find a decent cab and front clip
Old 04-10-2008, 09:17 PM   #4
sandhillmike
Let's try again
Old 04-11-2008, 05:02 PM   #5
solidaxel
solidaxel's Avatar
Good project and half way there!!
It looks like a newer rear end, now would be a perfect time to change out the front suspension.
I would stay away from the 54 55 beds as there are different deeper for your frame from the looks of the rear x-member. The cabs should fit stay with Chevy and not GMC if it is in fact a Chevy chassis
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-11-2008, 06:31 PM   #6
Daniel U
Daniel U's Avatar
Mount a seat and drive it as is! Good luck with your build. Keep us posted. As stated before, there are some differences year to year. My '54 sits on a older chassis. I had to have the chassis modded to fit the '54 bed.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-13-2008, 03:35 AM   #7
51 68CHEVY
the rear cab mts are a shackel type one on each side at the rear of the cab,and the front has two flat tabs that are outboard of the frame inline w/ the dr. edge. thats 47-55 1st. series. and the beds changed in 1954 on up but are the same from 47 to 53. hope this helps
51 68CHEVY is offline   Reply With Quote
Old 04-13-2008, 04:58 AM   #8
sandhillmike
Thanks guys.
