Old 04-09-2008, 03:13 AM   #1
lowriden58
lowriden58's Avatar
need help deciding rear gears...
ok im pretty much new here but anywho.. here is my specs.
fully built 355 10.5:1, comp 284/296 cam, AFR 195 heads, edelbrock airgap, holley 750 double pump, MSD HEI, running serpt setup.
trans is a TCI streetfighter 350 with a b&m 3k stall.
now for the "goodies" ill be running a 200shot of NX. I just pulled the rear apart and found 3.07 gears and a "open" diff.
what gears would you guys run? im thinkin a 4.10 myself.. maybe just maybe a 4.56. ill be on 28" slicks. Thanks for the help
*edit* forgot to mention its a 71 C10 LWB with a 12bolt
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 04-09-2008, 05:10 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: need help deciding rear gears...
Street - 4.10 or 3.73
Strip = 1/4 = 4.56 or 1/8- 5.13
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 04-09-2008, 05:18 AM   #3
ChevyFan24
Junior Member
I agree with 1968SWBBigBlock .
ChevyFan24 is offline   Reply With Quote
Old 04-09-2008, 06:09 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it's street, and you have a non lock up tranny, you'll need to be closer to the 4.10 instead of the 3.73.
Old 04-09-2008, 03:44 PM   #5
lowriden58
lowriden58's Avatar
cool, thanks guys. truck is gonna be street/strip and some light hauling here and there so ill just go 410s
