Old 04-09-2008, 03:15 AM   #1
uncle
72 1 Ton Rolling Frame.
It's a 157" that's been lengthened around 24". I have the rear drums and hardware. It comes just as you see it w/4speed trans. It supposedly has 40k on the frame and suspension,but has been sitting outsine for a while. $450 OBO. It does need to be plated on the ext. if you leave it that way. I do have the wheels which are split rims.
uncle is offline   Reply With Quote
Old 04-09-2008, 03:17 AM   #2
uncle
Re: 72 1 Ton Rolling Frame.
Few more.
Old 04-10-2008, 12:57 AM   #3
uncle
Bump.
Old 04-14-2008, 09:08 PM   #4
uncle
Bump.
Old 04-22-2008, 05:26 AM   #5
uncle
Any parts before I cut it up?
Old 04-22-2008, 01:17 PM   #6
OhioDan
OhioDan's Avatar
How much for the rear upper shock mounts? Shipped to 45344?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-22-2008, 07:41 PM   #7
BIGJAKE97
BIGJAKE97's Avatar
how much for the clutch zbar frame bracket shipped to 94538, CA. do you know what size engine was in this frame? thanks, jake
67 short fleet
71 blazer 4x4
72 blazer 2wd
76 gmc sierra 3/4t 4x4
62 bel air
01 blazer extreme
member 11,943!
BIGJAKE97 is offline   Reply With Quote
Old 04-22-2008, 07:53 PM   #8
uncle
It was a 402.
Old 04-23-2008, 03:50 AM   #9
uncle
$20 each shipped for shock mounts and z-bar frame bracket.
Old 04-23-2008, 04:31 AM   #10
BIGJAKE97
BIGJAKE97's Avatar
pm sent for the z-bar bracket.
67 short fleet
71 blazer 4x4
72 blazer 2wd
62 bel air
01 blazer extreme
member 11,943!
Old 04-24-2008, 11:44 PM   #11
OhioDan
OhioDan's Avatar
Unhappy Re: 72 1 Ton Rolling Frame.
Uncle, I'll have to pass for now. Something came up and money is needed elsewhere. Thanx for you response.
Old 05-01-2008, 08:56 PM   #12
BIGJAKE97
BIGJAKE97's Avatar
bracket recieved. no torch or grind marks! i'm very happy. thank you, jake
67 short fleet
71 blazer 4x4
72 blazer 2wd
62 bel air
01 blazer extreme
member 11,943!
Old 05-15-2008, 03:56 AM   #13
ldg72chevy
I need the front two hub/rotors. Do you still have these? I have cracks in both of mine. I could come get them as close as you are. Thanks. Also, how much?
ldg72chevy is offline   Reply With Quote
Old 05-15-2008, 04:12 AM   #14
uncle
I'll check ,but I think they are bad. They are the same from 71-90 I think.
Old 05-15-2008, 05:30 PM   #15
ldg72chevy
I just checked. They are 1.5 inches thick. The 71-72 are 1.3 inches. As long as they are not cracked, with the low miles, they should work. Thanks.
Old 05-16-2008, 06:00 AM   #16
uncle
Sorry,but the rotors are shot. Looks like someone forgot to change the pads for years. Both have deep grooves.
