04-09-2008, 04:42 AM | #1 |
4 spd swap
ok ive been thinking of throwing my 355 and my muncie m21 in place of my 305/th350 in my shortbed i know there the same leingth and the mount and yoke are the same but i was wondering where the shifter will fall in the floor and maybe if anyone had any pics of car tranny convertions? also i was debating wether to go with an older manual zbar setup or the hydrolic with the slave, i went zbar on my last convertion but thats just what i had avalible at the time what do all of you think?? thanks alot -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
04-09-2008, 08:15 AM | #2 |
It'd be alot cooler if you did
Re: 4 spd swap
I have my whole truck torn apart right now, but I have the same exact set up, and I will tell you it does fit, but barely. Get the Hurst shifter and installation kit. They make one that is meant for the application. It's expensive but well worth it.
I also have a z bar. it took some slight tweaking but I got it to work. |
04-10-2008, 03:45 AM | #3 |
On a budget like Fred Sanford
Re: 4 spd swap
I've got an M21 in my truck too. Here's a picture, it kind of shows you where the shifter placement is. The trans is in neutral in this pic. Second and fourth gear puts the shifter about an inch in front of the bench seat, just right! I'm using Hurst stick # 5384331. I've also got a Z-bar setup, I'm not a fan of hydraulic clutches......I have nothing but trouble with the hydro clutch in my camaro.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 04-10-2008 at 03:47 AM. |
04-11-2008, 12:35 AM | #4 |
Re: 4 spd swap
thanks for the pic i guess ill do another z bar setup i was leaning that way anyway so i didnt have to get a new bellhousing for the slave ill post pics when i staret the swap -kyle
04-11-2008, 05:03 AM | #5 |
driving is in my blood
Re: 4 spd swap
Im glad I have buckets in my 78 with the shifter where it is. Not sure how it would fit with a stock bench but they [hurst] do have different sticks to custom fit if needed. I used an indy universal hurst shifter.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
04-11-2008, 06:41 PM | #6 |
Sb 400 club
Re: 4 spd swap
I hope to convert mine to a manual trans some day and can't wait to see your swap. Good luck
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
