Axle U bolt size
I need to get longer U bolts for the trailing arms I am making. Do you think that a 1/2" diameter bolt would be strong enough? Thanks for any help.
Questionable
Re: Axle U bolt size
someone else will know for sure, but i'm pretty sure the front control arms on the 67-68 pickusp use a 1/2" u-bolt to hold the control arms on and the 69+ use 9/16"...but it could be 9/16" on 67-68 and 5/8" on the 69+, respectively. those bolts are a lot shorter too. will be interested to see input - a lot of guys are all about "overkill", so ....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Thanks for the reply Shifty, I think My stock U bolts on the front were 1/2" also(1965). Thats why I thought 1/2" for the rear would be ok?
Han anyone needed to buy longer U bolts for there rear axle? If so what diameter did you go with?
They are 3/4.
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
