Old 04-09-2008, 04:59 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Rubbing panels. (non-perv)
What do you guys do about the panels that rub against other panels. Like the fenderwells where they are bolted to the fenders.. Thats just a matter of time before that gets metal to metal and starts rusting....
What do you guys do with those areas when reassembling? Do you do anything special there???
lyrikz is offline   Reply With Quote
Old 04-09-2008, 06:22 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Rubbing panels. (non-perv)
I took the fender wells of my 69 Chevy couple of months ago and noticed some rust buildup but it wasn't too bad after about 15 years when I had them off the first time. Fortunately I'm not in the "salt on the streets" belt here in Texas.
Not sure what a person can do other than sand the mating surfaces real good and paint them with a good type of rust preventative paint. Moisture and dirt grime will creep into those crevices no matter what you do, though. I suppose a person could use some sealant in there.
68gmsee is offline   Reply With Quote
Old 04-09-2008, 06:25 AM   #3
lyrikz
PITbut
lyrikz's Avatar
Just wonder if there is some better design or something. I know two metals rubbbing together the paint will come off REALLY quick and then rust is RIGHT around the corner.... I just want to do this once, and do it right....
Old 04-09-2008, 06:38 AM   #4
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Maybe try some Welting like the older Trucks Used?? Let us know what you end up using, I will need to do it to the 67 once i get it ready for paint............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 04-09-2008, 03:28 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Tighten the crap out of your front clip. It shouldn't move very much at all. You're "over imagining" how much the body parts flex
I used fender welting on my rear step fenders.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-09-2008, 04:41 PM   #6
68gmsee
Active Member
68gmsee's Avatar
67ChevyRedneck is right regarding tightening/flexing. I noticed just minimal surface rust on the mating surfaces where the two metals were against each other. The rest of the surface areas still had paint. I believe I used black rustoleum on them. That was 15 years ago and probably could had gone a lot longer without major rust damage.
Most of the really bad rust that I've noticed on the inner fenders has been towards the front under the battery area. I use a plastic battery protector on my trucks like the ones used on boats but without the lids.
http://www.academy.com/index.php?pag...rine/batteries
Old 04-09-2008, 06:30 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
check with your local paint supply store. I know my buddy used a clear plastic adhesive tape made specifically for this on my 56. I have also seen him use the soft side of the adhesive velcro for this as well.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
