Old 04-09-2008, 06:57 AM   #1
jcblue
jcblue's Avatar
need help.. ill try to explain
need to know what action to take.
im working on getting my body line right and im having lots of trouble with teh drivers side... started in teh rear and lined door to cab, but the fender to door is reaaly bad off.
the bottom has a gap about an inch wide, where as teh top of the gap looks ok..
i can put a jack under teh front cab support and jack it up and make them line up, but what course of action do i need to take to keep from having to jack up the front cab support?
P.S. i put all new cab supports in and im thinking the front pillar droped down some.. Can i just cut my cab support around teh bottom, jack it up where i want it and weld teh support back?
thanks guys
jcblue is offline   Reply With Quote
Old 04-09-2008, 07:33 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: need help.. ill try to explain
Did you replace the radiator core supports? The core position plays a big part in the fender to door alignment.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-09-2008, 08:06 AM   #3
jcblue
jcblue's Avatar
i have tried two different ones.. has teh same gap with both
Old 04-09-2008, 08:18 AM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
What if you loosen up all the new support bushings, get all the panels lined up and tightened down and then make a few rounds at tightening up all the bushings and watch your gaps as you do it. Just a thought.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 04-09-2008, 08:55 AM   #5
jcblue
jcblue's Avatar
ttt
Old 04-09-2008, 02:39 PM   #6
jcblue
jcblue's Avatar
anyone ever have this problem?
Old 04-10-2008, 03:25 AM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Did you replace cab mounts,core support bushings?The kits generally come with 69-72 core bushings which are taller then the 67-68 ones.If you used them then the core support is higher than it should be.This will make it impossible to line up your bodywork.
When asking questions you need to give the Specs of wht you are working on so we can better give suggestions.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-10-2008, 06:14 AM   #8
jcblue
jcblue's Avatar
my bad.. its a 72 SWB.. i did replace all teh bushings.. i think i may have got it tonight, i shimed the front left of the cab and got the fender lined up pretty good. i appreciate yalls help.
now im having probs with my hood.. it never ending it seems.. lol
Old 04-10-2008, 06:16 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
ttt
Danny
Shyguy is offline   Reply With Quote
