Old 04-09-2008, 08:20 AM   #1
lester622
dual tank selector switch ....
where can i get one of these switchs new? its the switch inside the cab that lets u select between the 2 tanks.
lester622 is offline   Reply With Quote
Old 04-09-2008, 08:36 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: dual tank selector switch ....
Napa carries them
Line: ECH
Item#: FS500
Price: $11.49
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Product Features:Three position MOM ON-OFF_MOM ON
four spade terminals
reversing rocker. Fits 1.5"x1.25" Rect. hole. Used on Carb and Diesel applications.
# of Terminals:4 Terminals
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-10-2008, 10:15 PM   #3
copperchevy
copperchevy's Avatar
Gm parts dealerships carry them also.
Mexican
copperchevy is offline   Reply With Quote
Old 04-10-2008, 11:06 PM   #4
kevinr1970
From a GM dealer if nowhere else.
I bought one for my '86 GMC about a month ago.
NAPA or any other outlet might be cheaper though.
What year truck are you working with?
I made the mistake of buying two from the B&S forums here only to discover that both only worked for 1987 and newer (to 95?) trucks.
I am now stuck with two switches I can't use...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-11-2008, 07:45 AM   #5
lester622
1989, so theres different switchs for different years?
Old 04-11-2008, 10:32 AM   #6
BLE 'BURBAN
If your's is a crew cab then the one I listed above is the one you need. It's made by POLLAK same as the selector valve it controls. They're both still available from your local G.M. dealer as well.
Old 04-11-2008, 07:57 PM   #7
kevinr1970
Originally Posted by BLE 'BURBAN View Post
Attributes:
...Used on Carb and Diesel applications.
Are you sure about that? It says carb and diesel applications? '89 would be TBI.
2000 Tahoe Limited
Old 04-11-2008, 08:17 PM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
As far as the selector valve it self, I believe there is only 1 available anymore. Part number 14029228. This valve is the latest design that fits TBI gas and diesel as well as supersedes all older valves. I also believe it is intended to be used with switch D7003 (AC Delco part number). The AC Delco Part catalog shows these two items cover 1981-1991. I am sure it covers more years but their catalog only goes back to 1981 on many things.
I remember when I converted my truck over to the later design I needed both the selector valve and the dash switch. Finding the pig tail to plug into the selector valve is a PITA and not available through GM or the aftermarket that I could find anyway.
14029228
D7003
DirtyLarry is offline   Reply With Quote
Old 04-11-2008, 09:19 PM   #9
BLE 'BURBAN
Yep it'll work on a T.B.I. model as well.
