Pics per request for Panel lovers
I received a request by PM to put up more pictures of my panel truck.
Here are two photoshows of my '69 panel. The first is before lettering: http://photoshow.comcast.net/watch/HF8TA8er After lettering: http://photoshow.comcast.net/watch/dq2Pj2Dr Dial up beware...big files.
'52 Buick Special Dlx 2dr. sedan, '68 Camaro '69 C-10 Panel, '07 Toyota Taco SR-5 "Try to be the person your dog THINKS you are" |
BlahBlahBlah
Re: Pics per request for Panel lovers
That is a nice panel. I didnt realize it was bagged. Now I understand what you were talking about in the PM.
Someday I hope to have mine as nice as yours. |
Insert Title Here
wow, that is real nice... good job
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Old School, New Style
Looks fantastic !!
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
Now I have something to shoot for, but you've set the bar pretty high. If my '68 is ever half that nice, I'll be a happy guy.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
![]() Join Date: Aug 2005
One of the nicest panels out there
Nice panel.
Nice truck! Is that a Caprice wagon in the driveway? I have a '92 also. Tell me more about the compressor you used for the airbags. I would like to have a belt driven pump on my '69 burb similar to that setup.
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around 1968 C10 Suburban, 350cid, 700R4, bent frame 1968 C20 Suburban, no motor, trans or interior (SOLD!) 1953 Packard Ambulance 1992 Caprice wagon |
Nice work...
Ironhead Mike '68 Panel 402BB '84 Shortbox 4X4 '85 Blazer '97 Silverado Ext. Cab |
#10 | |
The compressor: I made some brackets and mounted a Chrysler V-2 A/C compressor with the expansion valve removed. I put a small cartridge filter on the intake side. I put 12 volts via a switch to engage the A/C clutch when I want it pumping air. I chose the Chrysler A/C compressor because it has a crankcase and doesn't require oil in the freon to lube it like the newer compressors do. It really gets it done quickly. I can fill the reservoir tanks in minutes from dead empty.
Yup, I'm comp-useless
Awesome panel!
Where did you find the info on running the Chrysler a/c compressor for the bags? Interesting....very interesting. I may have to look into a set-up like that, when I get around to baggin' my 'burb.
1972 Chev Suburban(ongoing driveable project) 2010 Harley Wide Glide 1996 Subaru Outback(daily beater) !992 T-Bird Super Coupe(yet, another project) 1995 GMC Suburban(will be for sale, soon) 1995 Dodge 3500 Club Cab(Cummins 12V) 2001 Freightliner(Cummins Powered Money Maker) |
I thought of using the Chrysler V-2 after reading a post on a "Rock Crawler" forum I stumbled on while searching for something else on Google. The post described a guy using an A/C compressor off of a Ford/ York A/C system. He was using it to re-air up his tires in the field. I guess rock crawlers lower their tire pressure to increase traction but need to add air for the drive home. Anyway I also found that there were some kits available to add on a York style compressor to Ford Broncos and Jeeps but the kits were ridiculously expensive and nothing for a Chevrolet. I had a Chrysler V-2 already and I started thinking about it and conferred with an old friend who was a #1 line mechanic for a Dodge dealership until he retired and we came to the conclusion that it should work great. It does work killer. I put an air chuck under the hood and keep one of those yellow cheap coiled hoses in the panel so I can pump up my tires or any one's tires. I can shunt the solenoid air valves if they screw up and pump the bags manually should I need to. I had to do that once and it was a life saver or should I say a tow saver. I can hook it up after washing my engine and blow dry the engine compartment. I suppose I could have used a York but the V-2 looks cooler than the blocky York.
'52 Buick Special Dlx 2dr. sedan, '68 Camaro '69 C-10 Panel, '07 Toyota Taco SR-5 "Try to be the person your dog THINKS you are" Last edited by 69panel; 04-11-2008 at 12:18 PM. Reason: forgot something after I posted |
#13 |
Thanks for the info... I may hit you up in the not-too-distant future, for a little more detail on your system, if that's ok.
A quick trip to one of the self serve "recyclers" should net me an a/c compressor rather cheap; besides, it's time for a little rootin' around to find "hidden treasure", anyways.
#14 | |
with the V-2 compressor to drive it while the other groove drives my A/C. I litterally used two by four wood scraps stacked up to hold the V-2 in position with good pully alignment while I measured to fabricate pieces and locate bolt holes on the face of the block or cylinder head to attach it with. You will understand when you pick one up...that puppy is heavy. I really could have used a hand but I had no one to help.
#15 |
![]() Join Date: Nov 2007
Thats one nice panel! Is that you supplying the background tunes to the slideshow?
If you get lost, come back and tell me where you are. 72 Burb, 86 1 ton crew cab dually. ![]() |
#16 |
I am a Referee of life.
I would like to see more interior shots.I assume the rear walls are covered with something but it looks like the floor is stockish.
The truck looks great.I really like that blue.Someone(maybe you) did some over the top bodywork on it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#17 | |
Photoshow offers. I've even tried adding artists I like as the background music but again the program will not allow it.
#18 | |
The floor is stock and there is no rot...I hope to get around to at least refinishing it one day. The interior is Mahogany paneling stained a reddish cherry color and the urethaned. Thanks for the compliment on the body work...That's three and a half years worth of body and mechanical work and a month and a half of guidecoat blocking. Another few weeks of color sanding and buffing after painting. I still have some of the roof to go. As I worked on it it seemed to get bigger and bigger. It really is a lot of real estate to cover. It's like color sanding two regular vehicles. I wish I had a before picture of it but you'll just have to take my word for it when I say it was rough with lots of rust below the beltline. I had to fabricate a lot of patch panels all the way round the vehicle. Partial floor pans and the bottom of both door jams. The top jam on the passenger side. Rocker panels, inner and outer, below the front doors. The rear barn doors took two sets of doors to make two good ones and several patch panels on the rear door jams. Patch panels on the cowling and firewall...hidden but never the less rotten and full of sand, dirt and leaves where it's supposed to drain. I thought I'd never get through it...I burned out and had to walk away several times. Then I'd see a Trucking magazine or a TV show build and get inspired to go back at it. I've kept up with how much I've spent and it's a huge amount of money but spread over time it's not so bad. I learned that next time I'll buy one in better condition to start on. The satisfaction I guess is having done it all myself. ![]()
#19 |
Thanks for the pic's. that's really an awesome "finished" project you have there.
#20 |
its all about the +6 inches
I'm gonna have to subscribe to this one.... i like the compressor idea. brilliant!
