Old 04-10-2008, 04:23 AM   #1
JohnnyBad
V8 conversion from 250 6 questions
Okay, I've read a bunch of posts but can't seem to find what I am looking for.
The truck is a 67 short box that I've had for about 25 years. Slept most of it's life in a heated garage. Still has the original 250, 83K miles now.
Bought a rebuilt 350 a number of years ago. It has been on the engine stand in the garage since. As time goes by, the I am coming to realize the parts are probably worth more than the whole based on date codes etc. but i think I'll give a shot at putting it in anyhow. I told the wife all I really wanted to do was spin the tires down the street once as I missed out on that as a kid. The block is a 350 4 bolt with a 70 date code, and flattops. It came with a rebuilt set of 202 heads, also 70's vintage.
Questions - do I have to replace the 250 engine mounts with a set from a V8? It also has the original powergride. Does anything have to be changed from a mounting perspective to drop in a turbo 350? Does a cable gas pedal set up bolt right into the 67 or does it need modifications? If so I'm looking for one.
Also looking for alternator brackets. I had a buddy give me a engine compartment wiring harness from a V8 that I was going to utilize in the swap (about 15 yeears ago). Is there anything else that I need to take into consideration (besides the rad) to do the swap. Sorry for the long winded message.
JohnnyBad is offline   Reply With Quote
Old 04-10-2008, 04:46 AM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: V8 conversion from 250 6 questions
I just did this swap. You will need the V8 towers to make everything you have work. I swapped from a 6cyl 3spd to a 350/350 setup and I had to cut my driveshaft 3inches. other than that it was straight forward.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 04-10-2008, 04:47 AM   #3
HavinSomeFun
also, I found everything I needed from board members except my new 4 core radiator.
Old 04-10-2008, 05:08 AM   #4
bhoeger70
bhoeger70's Avatar
I put a v8 in a 68 that had a 6 and it bolted right in, get didnt change the mounts or anything the engine sits back a little farther than a stock v8 truck but still fits nice. You might need to relocate the trans crossmember also to swap transmissions.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
