Old 04-10-2008, 07:41 AM   #1
Pont406
I keep on burning up front shoes
I replaced front brakes and drums 3000 miles ago. Every time I drove it, it smelled like a burning clutch. I didn't pay much attention to it untill I felt a brake fade. I checked brakes and found heat cracks on the front only. I replcaced front drums and shoes again. At the same time I replaced all the brake hoses, wheel cylinders and a master cylinder. Drove it over the weekend and I still smelled a burning clutch. Only thing left is a proportioning valve. Anyone had a similar problem?
Pont406 is offline   Reply With Quote
Old 04-10-2008, 11:33 AM   #2
oldspowered67C10
Re: I keep on burning up front shoes
How tight are you adjusting the front brakes? I guess you could drive it and compare front brake vs. rear brake temps to see how hard the brakes are working.
oldspowered67C10 is offline   Reply With Quote
Old 04-10-2008, 03:51 PM   #3
bigsnookmaster
bigsnookmaster's Avatar
Make sure the rear brakes are adjusted properly,and you might try new hardware kits.Those return springs fade away after time and heat gets to them.Good luck
bigsnookmaster is offline   Reply With Quote
Old 04-10-2008, 07:05 PM   #4
chris71
chris71's Avatar
what kind of shoes are they?cheapo's? organic? metallic? if they are cheap organic no-name brand ones, maybe consider upgrading? make sure your MC is drum/drum. disc brakes require higher pressure so the front disc MC is built that way, theoretically the higher pressure may be telling your front cylinders to start braking earlier. just thinking out loud here.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 04-10-2008, 08:00 PM   #5
airdale94
airdale94's Avatar
How hard is your brake pedal. The pushrod in back of the master cyl. is adjustable. Sometimes they need to be screwed in or out. Your shoes might also be hanging up. Check for proper release. Just make sure you don't push on the brakes to hard with your drums off or you will blow out your wheel cyls.
airdale94 is offline   Reply With Quote
Old 04-10-2008, 10:04 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Unless I'm remembering wrong, truck with drums front and rear don't use a proportioning valve. Sure seems like my 69 K20 doesn't have one and I added one to my 70 K5 when I swapped in a disk front axle. Does your truck definitely have one installed?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-10-2008, 10:09 PM   #7
rambler
MOVE OVER
rambler's Avatar
I usually get the new hardware kits as well.. not that expensive and good insurance.. since I'm prone to dropping and losing parts when I repair things...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-10-2008, 11:43 PM   #8
Blazer1970
Blazer1970's Avatar
Your rear brakes are not bled properly or not working for another reason.
Blazer1970 is offline   Reply With Quote
Old 04-11-2008, 12:17 AM   #9
BurnoutNova
BurnoutNova's Avatar
if it does have a prop valve, that might be the probleom, drum brakes dont need more psi in the front than in the rear like disc drum setups do. if your getting to much psi in the front the fronts will wear much faster that the rears.
make sure the backing plates and all the moving hardware is clena an well lubricated. if it binding up it may be engaged all the time while your moving
BurnoutNova is offline   Reply With Quote
Old 04-11-2008, 02:34 AM   #10
BurnoutNova
by the way, thats a neat ventura. thats what it is, right? the tailights look wider than a nova
Old 04-11-2008, 03:57 AM   #11
oldsmobilekindofguy
who needs a creeper when you can lay an old coat or pair of coverals on the ground, that is what I always do, don't press the pedal down so hard leadfoot
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 04-11-2008, 04:42 AM   #12
Pont406
I got this truck last year and I didn't do much to it yet. PO installed primary shoes on one side and secondary on the other side. I don't have any private own parts places around. I do have napa closed by but I try to avoid going there. Unless you are buying reman motor or a big items they really don't want to deal with you. I bought all the parts at Autozone. I tryed adjusting on the loose side with no difference. Rear shoes are working because they are locking up at 60mph and up during panic stops. That's why I decided to redo brakes all the way around. I will figure it out. Here is a pic of a proportioning valve. Does this looks correct for a 69 c10? Thanks
Old 04-11-2008, 04:49 AM   #13
BurnoutNova
thats just a t- block, not a proportioning valve. it is correct for a drum/drum setup.
it doesnt make sence that your rears will lock up ar 60, but the fronts are obdviously applying pressure all the time. thats like 2 opposite probleoms
Old 04-11-2008, 07:03 AM   #14
knsmodels
I make Models
knsmodels's Avatar
I had this very same problem with my Chevelle (drums on all fours) I replaced all of the same things and the problem persisted....turned out my "new" master cylinder was bad.....replaced it again and all was fine....good luck
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 04-11-2008, 11:24 AM   #15
oldspowered67C10
Pontiac motor, cool.
Old 04-11-2008, 05:55 PM   #16
Olden Days
Living In The Past
Olden Days's Avatar
if it happened as soon as you changed shoes and drums and nothing else I would say you have them adjusted too tight.
Olden Days is offline   Reply With Quote
Old 04-11-2008, 06:18 PM   #17
Brad
Out of the carpool lane.
Brad's Avatar
So I take that those cracks shown in the top pic are bad??? My original Camaro has always done this with it's front shoes but I've never worried about it. I'm watching this thread closely to find out more....
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
