Old 04-10-2008, 04:26 PM   #1
djracer
djracer's Avatar
cheap street 4 link
My little brother has a weekend cruiser (59 chevy Pu) that I want to hang an explorer rearend in and a cheap street 4 link. He will never race it just cruise. I have seen the bolt in stuff but it too expensive!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-11-2008, 02:51 PM   #2
sgrier
Re: cheap street 4 link
hey kevin
***************** and kplinks.com both offer weld in 4 links for around the 300 dollar mark, not sure if these kits have panhard bars included. check em out let me know what u think. hows your race truck comin. see ya.
sgrier is offline   Reply With Quote
Old 04-11-2008, 09:13 PM   #3
TH53
Guest
Posts: n/a
I ran into a problem with 4 links/ 4 bars and the explorer 8.8, the axel tubes are big on the explorer rear end and most 4link/4bars are designed for standard 3" axel tubes, also depending on the placement of the bars the ends of the 8.8 rears taper at the ends so you would have to sleave them depending on the desired location of the 4link mounts.
Old 04-12-2008, 12:53 AM   #4
jlaird
jlaird's Avatar
you can get any size axle bracket at SD. Just let them know your axle diameter.
jlaird is offline   Reply With Quote
Old 04-12-2008, 05:30 AM   #5
djracer
djracer's Avatar
Thanks for the heads up guys! I am wanting to upgrade the motor in the drag truck! Anyone want a nasty 468?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-16-2008, 06:45 AM   #6
leftcoast66
leftcoast66's Avatar
Also check out thebagshack.net usually has some good prices, devon's a good guy also. He's got a few 4 link kits on there also.
leftcoast66 is offline   Reply With Quote
Old 04-16-2008, 02:08 PM   #7
djracer
djracer's Avatar
I think I got him talked into one of the bolt on setups! Have you guys had any luck with one of those? They all look the same in the pics.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
