Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-10-2008, 07:23 PM   #1
LILRED66
LILRED66's Avatar
4-5-6 Chevy Truck low hump tranny cover & front cover
I have a low hump tranny cover and front cover for a 4-5-6 Chevy Truck. The low hump tranny cover came on the three speed column shift and factory automatic tranny 4-5-6 Chevy Trucks.
If you are converting to an automatic transmission or column shift manual transmission and desire the factory look...or simply like the increased leg room of the low hump tranny cover configuration, this is the ticket.
The front cover is required, in order to convert from a high hump tranny cover to a low hump tranny cover, to meet the firewall, without modification. The factory low hump tranny cover and front cover are spot-welded in place at the factory, therefore they will have to be spot-welded or bolted in place on your cab. Also, you will have to remove the high hump front cover from your firewall, in order to install the low hump tranny cover and front cover.
The first $150.00 takes the low hump tranny cover and front cover, including removal, packaging & shipping, via UPS, Ground.
Let me know if we can help you with your 4-5-6 Chevy Truck parts in the future.
LILRED66 is offline   Reply With Quote
