Old 04-10-2008, 07:58 PM   #1
chris71
chris71's Avatar
brake pedal ratio
I just read and article that said that some car manufacturers put different brake pedals in there vehicles depending on whether it was a power brake or manual brake vehicle, meaning that each one had a different pedal ratio (which affects braking) the article used the early must*ng as an example. does anyone know if this is the case for our trucks? just thinking about all those guys that have switched over to power for safty reasons, or would it be a mechanical advantage for the power guys to switch over to a manual pedal from what the article says.
here is the article:
http://www.hotrodheaven.com/tech/brakes/brakes6.htm
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 04-18-2008, 08:42 PM   #2
chris71
chris71's Avatar
Re: brake pedal ratio
ttt
Old 04-18-2008, 08:48 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
IIRC, the only thing that's different essentially is the vacuum booster. Everything else is pretty standard right down to the holes on the brake pedal rod.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 04-19-2008, 06:20 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there's 2 holes on your prake pedal. one for manual, the other one for power. Same P/N pedal either way.
