04-10-2008, 09:22 PM | #1 |
Anyone running bags in the rear for 2/4 drop
I like the 2/4 drop but I still want to be able to haul a load and tow a load. Anyone using bags in the rear when loaded to do this if so how has it worked out? Thanks!
04-11-2008, 03:38 PM | #2 | |
Living Legend
Re: Anyone running bags in the rear for 2/4 drop
I personally havent done it but I worked with a guy that did it on an '86 suburban and and he used a helper bag setup similar to this and said it worked out great.
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony |
04-11-2008, 03:45 PM | #3 |
Thanks for the reply! I had heard that if you do a 4 inch drop in the rear that you can wide up with a problem when you carry a load. That is why I wondered about the bags in the rear to support the additional occasional weight
04-11-2008, 03:57 PM | #4 |
Living Legend
I dont remember for sure but i believe that my '81 has a 5 drop in the rear and let me tell you from experience it doesn't take much of a load on it, (trailer or bed) to really tick you off driving down the road. Me after pulling a lincoln welder ~~~>
04-12-2008, 01:19 AM | #5 |
My 74 has the 8-leaf 'HD' spring option, flip-kit, + Bell Tech drop shackles & no c-sections. You prob had alot more clearance than me .
04-12-2008, 03:23 PM | #6 |
Living Legend
YEAH WOW!... Once I break that initial stiff spot in the suspension though its all down hill from there i bought the truck already dropped and never thought to look at how he did it before i bought it. but hey its ok i'm building a new chassis to put it on now with full air so i'm not too worried bout it anymore.
