Old 04-10-2008, 09:23 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
my Vent windows may be
assembled incorrectly, why do I think this?, well when I put on the locking type handle the handles rub real hard on the rubber to get them open. so can I ask for help? it looks that the frame work of the vent window where the new rubber seals are the out side frame is narrow and inside the cab they are wide. hummm let me try to improve this. where the handle locks on the frame, the inside portion of this frame is wider then the outside portion of the frame. can someone please post close up pictures of what is correct for the assembled frame inside and out where the vent handle locks to verify if this is assembled wrong or not.... please
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 04-10-2008, 11:39 PM   #2
tphsmith
tphsmith's Avatar
Re: my Vent windows may be
well maybe Im making this confusing so can I ask some one to take close up shots of thier vent window vertical support post that seperates the vent window from the regular window, id like to see pics of inside the cab of this post and the outside of the cab of the same post. you know the vertical post the vent window handle locks on
Old 04-11-2008, 02:13 AM   #3
Sammy
Some claim it's the quality of the rubber repo stuff. I have seen this problem also. Once you verify the assy is correct all you can do is trim & keep the sucker closed. Thats why they are 100 a piece assembled new.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-11-2008, 09:34 AM   #4
Mint68
Mint68's Avatar
Post some pics of the problem.
Mint68 is offline   Reply With Quote
