three on the tree is sloppy as can be!
i'm looking for a good way to tighten up the rod linkage from the column shifter to the trans on my 69 C10.. i haven't been able to find bushings for it and haven't had much luck with making anything that works well. the main source of the sloppyness is where the rods connect to the trans. the pins on the rods have holes for cotter pins in lieu of threads and are about half the diameter of the hole in the linkage on the trans. i'm going to try cutting down skateboard bushings and threading the end of the pins in the rods... not sure how well it'll work though. anyone got any bright ideas or know of a source for parts? LMC doesn't have 'em
Re: three on the tree is sloppy as can be!
http://www.classicchevy.com/product....4&dept_id=1889
These should work. Or you could search for bushings on http://www.mcmaster.com/. They should have something that will work. Thanks,
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() Last edited by Blue71LWB; 04-11-2008 at 12:49 AM. |
Aren't these still available through Chevy parts dept. I know I bought some a couple of years ago.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
I had an original 64 Impala 2 door with Three on the Tree. Same thing happened to me. New bushings kit from a Chevy parts place and your done. Do not cut anything, when you buy the kit it becomes perfect again.
Usually after replacing the bushings & still it locks up between 1st & 2nd you adjust the tube for more tension. If you run out of room then the shifting tube is worn too much inside the column.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
thanks! didn't expect chevy to have 'em.
![]() Join Date: Jul 2004
I saw it on the board sometime, that the rubber bushing that fits the automatic column is still available, don't know if it would be aftermarket or GM but it is supposed to fit the 3 speed linkage, don't know if top an bottom bushings are the same on that, but they are supposed to fit. might be worth a shot, might want to do some research, I can't verify that is true though.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
3 Speed Manual Column Shifter Adjustment by GREEN MACHINE
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
Why does it taste purple?
Anytime I had a problem with mine,I just wiggled the linkages and all was good again.I'd rather have my 3spd on the tree back then have a Th350.The only reason I swapped it out was so my g/f could drive the truck.
