Old 04-11-2008, 02:33 AM   #1
eke82
best place to find eaton rear end brackets?
Went to fix the leaking brake cylinder on my 72 3/4 4x4. After pulling tire off and setting my jack stand i looked down and the bracket on the bottom side of the rearend that the ubolt goes thru is cracked off in one corner. Looked in my lmc and classic industries books dont see anything wondering if anybody had one laying around for sale or know where to look?
thanks eric
eke82 is offline   Reply With Quote
Old 04-11-2008, 04:18 AM   #2
lowriden58
lowriden58's Avatar
Re: best place to find eaton rear end brackets?
lets see a pic of how bad its "cracked off" if its just a crack you may be better off just welding it back up.. with out removing the whole rear also. but all depends on how bad it is
BTW if you can weld it back i suggest beveling the edges of the old weld/ inside the crack for better weld penetration.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 04-11-2008, 11:36 AM   #3
JimKshortstep4x4
Is the bracket cast iron with a radius that fits the axle tube and it has (4) holes for the u-bolts?
If it is I should have one. I will look this afternoon as I am leaving shortly.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
