Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-11-2008, 06:55 AM   #1
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Tips for the new guy
I want to take the truck out to the new strip in El Paso. It will be my first time at a regulation strip.
I have 94 LT1 with headers and some mods in the compter. 4L60E, 3.73's and a posi, leaf springs.
Should I let it idle or runit up a bit before the launch? Manual shift or let the computer do it?
I'm running 255/70/15 Big O's.
Any other advice I need?
low'n slow is offline   Reply With Quote
Old 04-11-2008, 08:30 AM   #2
djracer
djracer's Avatar
Re: Tips for the new guy
Sounds sweet! Good luck at the track. Make sure you leave when you see the last yellow. If you wait for green you are dead late! Stay out of the water box. What are big o's? Try your launch both ways and shifting both ways but only change 1 thing at a time!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-11-2008, 08:32 AM   #3
blkboot
djracer have you every heard or canfeild heads?
blkboot is offline   Reply With Quote
Old 04-12-2008, 05:04 AM   #4
low'n slow
low'n slow's Avatar
Originally Posted by djracer View Post
What are big o's?
Big O tire is mostly a western US tire retailer.
Old 04-12-2008, 05:39 AM   #5
djracer
djracer's Avatar
I have and everything I have heard was pretty good! I haven't had any direct experience.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-12-2008, 05:52 AM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
I believe canfield was bought out by AFR .
If you feel it throw you back when you shift , you shifted to late .
I agree 3 rd yellow , dodge the water box , 5500 shifts , it it spins lift and let it hook and get back in it . Next pass roll in the throttle off idle . If it gets sideways get out and try again . If it hooks sideways it will go for the wall .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
