Old 05-03-2002, 05:28 PM   #1
project72lwb
Question new weatherstrip still leaks
I had a "professional glass shop" install new weatherstrip around the windshield and rear glass. However, during rain storms the windshield leaks in the bottom corner and the rear glass seal leaks from both bottom corners. Has anyone else had this problem ? Did I get some poor weatherstrip or poor service from the shop?
68 chevelle(garage queen)
72 cheyenne super(driver)
Owasso, Oklahoma
project72lwb is offline   Reply With Quote
Old 05-03-2002, 05:38 PM   #2
KNUCKLEHEAD
Thumbs up
I would try my best to take it back and have them do it again. The only big problem that I can think of is that the shop may not have properly prepared the surface, ie; rust or improper or no urithane sealant. Rust in the corners is a big problem in the 67 to 72 truck, especialy in the front lower corners of the windshield
KNUCKLEHEAD is offline   Reply With Quote
Old 05-03-2002, 05:52 PM   #3
tom hand
CCRider
tom hand's Avatar
Post
Have you resealed the rain gutter on top of the truck? This is a bigger site of leaks than the weatherstriping. It will appear that it is coming from the weather stiriping but it is not. I would bet that is were your leak is coming from.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-03-2002, 05:59 PM   #4
project72lwb
Post
What is the proper material and procedure for resealing the rain gutters. There are some areas that are deteriorated but I never thought of it being a point of entry for water. I can however visually see the water seep between the glass and seal on the rear window. All thoughts on fixing this are appreciated.
Owasso, Oklahoma
Old 05-03-2002, 06:16 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool
I just got done fixing my own front window. I too had a shop come out and replace it first, and afterward every time it rained it would leak. I had them at the house 3 times and never fixed it. Every time they said they put sealer along the top of the glass, well guess what? They never did, I did it myself and nomore leaks, been about a month now. I would think this is what's wrong with yours also, These guy's around here in sc say they don't like using sealer, after I called and complained.
Andy
71's Are for ever!!! or 67,68,69,70,72
71,factory tach,tilt for straight drive,gauges,ac,305 HO TPI with 700-R4 lowered,17" wheels
<A HREF="http://www.geocities.com/chevy71tpi/main.html]www.geocities.com/chevy71tpi/main.html[/URL" TARGET=_blank>
[URL=http://www.picturetrail.com/Andy4639]www.picturetrail.com/Andy4639</A>
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-04-2002, 08:22 AM   #6
jku72
Post
Same problem here, new rubber needs sealant, and a shop manual from 1970 confirms that sealant should be there, but many newer shops "forgot" how to do the oldies, and need coaching. I had to ride their ass the whole time to get them to do it, they tried every excuse, finnally threats worked.
jku
70 C30 CST Longhorn
68k10 burb
69 K5 beater
43 willys GPW
40 Chev coupe
67 catalina
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-07-2002, 03:49 AM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Post
These WS are leakers! Most shops have to reseal several times. One shop finally took it all back out-sealed the glass to the gasket-put it back & sealed body to the gasket. I just make sure the company/shop guarantees no leaks as long as their WS is in the vehicle. Good companies will.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
