04-11-2008, 07:29 AM | #1 |
nasty stuff in my oil?
I found all this junk about four months ago when I switched my valve covers out. Now I went back to get the casting numbers off of my heads, and it was back.
That was the drivers side. I cleaned it up, then went to clean up the passenger side and there was none there. Completely clean apart from the few oil spots. Should I put some engine cleaner in there? |
04-11-2008, 07:50 AM | #3 |
Re: nasty stuff in my oil?
04-11-2008, 08:10 AM | #4 |
looks like some water/coolant got in there. Possible bad intake gasket?
04-11-2008, 08:20 AM | #5 |
KEEP ON TRUCKIN'
Nasty chocolate milk looking mess. Coolant leak. Hows your oil look?
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
04-11-2008, 08:24 AM | #6 |
its all about the +6 inches
being that it's only on one side...
How often does the truck get driven? Do you have a proper PCV system... PCV valve on one side, and a breather or fresh air hose to the air filter on the other side? If by engine cleaner, you are talking about the motor flush... I would recomend never putting that stuff in your engine. |
04-11-2008, 09:25 AM | #7 | |
04-11-2008, 03:56 PM | #8 |
It does look like water/coolant mixed with oil. From what is the question. Unfortunately I know what it looks like pretty well. I had the oil light come on in an old truck and when I pulled the dipstick out it looked like that stuff on the stick. No bueno. It had circulated it everywhere by then and very expensive/time consuming to get fixed. It looks like your problem is much less severe but check the oil just in case.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
04-11-2008, 08:06 PM | #9 |
Well it was on the PCV side, and none of it got through they system into my oil. My breather is clean too. I'll just reinstall my intake and see if it fixes the problem
04-11-2008, 08:11 PM | #10 |
Seen that happen getting the engine clean by washing with pressure washers & such. Also washing around the ol point style dist. and crackin caps at the car wash.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-11-2008, 08:26 PM | #11 |
i'd also suspect bad pcv system as the cause
04-12-2008, 12:21 AM | #12 |
I would change to a new PCV valve, make sure it is hooked up to constant vacuum. Then change to a high detergent oil like CASTROL. Run it for a while and see what happens. When - if- you change the intake manifold gasket, make sure you use thread sealer on the bolts as you can get coolent coming right up the bolt threads and that can get into the oil galley's. Usually when that happens, you will see coolent on the intake it's self and if into the oil, it would be visable on both heads.
04-12-2008, 07:49 AM | #13 | |
