Old 04-11-2008, 07:50 AM   #1
GreaseMonky81
GreaseMonky81's Avatar
Question Trying to lay frame on my 60' c/10?????
Ok this is what I got I have a straight clean 60 that had a frame off resto started before I picked it up, orginal owner passed away, and famialy sold it to pay the bill. Anyways I want to be able to drag frame on this one but I have a very small budget but am a decent welder/fabracator.
My question is, Is there a way to bag the front of this truck using the stock torsion bar control arms and not Zing the frame also any pics of some rear setups with out back halfing would be great I have looked, and looked and cant seem to find any info on this. Seems like everyone swaps over to later model front suspension. This will be my first bagged rie so sorry if I come across a little slow.
p.s. I will try and get some pics up as soon as I can figure out how to post them
GreaseMonky81 is offline   Reply With Quote
Old 04-11-2008, 08:01 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: Trying to lay frame on my 60' c/10?????
I went through this while building my truck. You cant lay frame with the stock front crossmember, unless you z your frame. The lower control arm mount points hang below the frame, so if you want to lay the frame past this point, you will need a z or a dropmember. As for the back, you will need a weld in notch, but its height really depends on your overall tire diamater. I assume you will be bagging this, but that is another can of worms!
PrerunnerRob is offline   Reply With Quote
Old 04-11-2008, 08:12 AM   #3
GreaseMonky81
Yes I am planning on bagging it. What about laying rockers thats lower then the rest of the suspension?
Old 04-11-2008, 08:41 AM   #4
GreaseMonky81
I looked on the porter built site at the dropmember but they dont have spindels and no one make cnotrol arms for the 60-62
Old 04-11-2008, 08:31 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
I would call Nate at Porterbuilt. I know people bolt in later crossmembers, so I can't see why a Dropmember wouldn't work...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-12-2008, 07:59 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Nobody makes aftermarket arms or spindles for the 60-62 due to the torsion bar suspension. If you're looking to lay frame, it's either a "Z" or a Dropmember. If you go the Dropmember route, you would need to update the spindles and brakes as well (my site is severely outdated, and not very well maintained... this should be changing here in the next few weeks!).
If you have any specific questions on the Dropmember, I will be more than happy to answer them.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-12-2008, 08:36 AM   #7
PrerunnerRob
Things required to lay out to the rocker:
Front end- Either the Porterbuilt dropmember and all the related components, including new control arms, spindles, rack n' pinion, etc
or
Z-the front end and make everything fit. This may be alot more work then you imagine, since the engine and transmission must come up at the same time. Also, if it is a manual tranmission, all linkage must be changed accordingly.
You will also need to cut the rear frame crossmember and plate it flat, it hangs way below the frame. While doing this, it's a good time to take care of rereouting the exhaust so it doesn't hang below the frame.
Rear-At a minimum, you will need a weld in notch. I tried to preserve my rear trailing arm setup on round 1 of my rear frame clip, and it was a waste of time. Do yourself a favor, run a paralell 4 link with a Watts link or a triangulated 4 link. Either way, no rear end lateral travel, and extremely solid.
I tried to do it on my own the first time around on my truck by skimping here and there, only to realize that all the parts would have paid for themselves in time. I'll post more if I can think of anything, let us all know how it goes!
Old 04-12-2008, 08:47 AM   #8
GreaseMonky81
What is the price of the dropmember, and do you have to go to a rack and pinion set up if so how much modifying to the steering column is required??
Old 04-12-2008, 02:01 PM   #9
jlaird
jlaird's Avatar
Nate can tell you exactly, but if you need everything from hub-to-hub your looking at a probably around $3000. This assumes rotors, spindles, arms, dropmember, rack, etc.
jlaird is offline   Reply With Quote
Old 04-12-2008, 02:55 PM   #10
LUCKIN-FOU
I'M NOT SCARED I HAVE A PLASMA
LUCKIN-FOU's Avatar
I would go with the Porterbuilt Drop crossmember. I would get rid of the torsion bars. If all else fails build a chassis.
Lou Santiago
US Navy Retired/World Traveler
Car Builder/Welder/Airport Investigator
garageinsidertv.com [FORUM]
WORK IS FOR PEOPLE WHO CAN'T FISH. I GUESS I'M SCREWED BECAUSED I HATE FISHING.
LUCKIN-FOU is offline   Reply With Quote
Old 04-12-2008, 04:23 PM   #11
PrerunnerRob
Its very easy to modify the column. I pulled marked my steering shaft for length, cut it, and then machined the end flat on 2 sides. It is 3/4" OD, which now fits perfectly into a DD Borgeson universal joint.
Old 04-16-2008, 09:26 AM   #12
GreaseMonky81
Ok have I have sold some parts and saved the cash and I think I may be ready for a dropmember what all does it come with and what is the price? Also will it lay wockers with a 30" tire and how much lift will i get? Have you made one of this for a 60 yet?
Old 04-16-2008, 05:54 PM   #13
Frizzle Fry
Frizzle Fry's Avatar
I don't think anyone has mentioned that the 60-62 frame has more issues for laying frame than just the torsion front end. They are a completely different frame than 63+. You are looking at cutting out the big X in the middle of the frame, boxing the rails, and installing new crossmembers at minimum. I'd just go with a 63-66 frame to start with. 67-72 can be made to work with body mount mods.
Frizzle Fry is offline   Reply With Quote
Old 04-16-2008, 07:10 PM   #14
GreaseMonky81
Whats the reason for cutting the X out of the middle? I knew the where different but from what i could tell the x could stay
Old 04-16-2008, 07:25 PM   #15
Frizzle Fry
To lay frame the center of the X will hit the ground inches before the rails. The rear portion of the X will just get in the way IMO, especially if you go with a 4-link.
Old 04-16-2008, 08:01 PM   #16
GreaseMonky81
I was gonna make a 4 link but try and use the factory trailing arms and trim the center of the x and plate the bottom of it
Old 04-16-2008, 08:49 PM   #17
leftcoast66
leftcoast66's Avatar
Frizzle makes a good point, yours would bolt onto a 63-66 frame. You would be able to keep your idea of using the stock back trailing arms for the setup, except you don't have to worry about the center x and getting it to work or cutting it out. Would give a good starting point w/ a 63-66 frame. Heck, you could bag the frame and enjoy the truck then swap em out once its all bagged. Easier to work on also.
leftcoast66 is offline   Reply With Quote
Old 04-16-2008, 08:53 PM   #18
GreaseMonky81
The truck is all tore down already that was the way I purchased it from the resto shop.
I have a plan for the back do I think I will stick with this frame that and since I am on a budget cant rally afford to buy another frame. That and this frame has already been Sandblasted and stuff like that.
