Old 04-11-2008, 06:03 PM   #1
Alex1
Alex1's Avatar
Need a small favour, please!
Could someone post iup a picture of a manual steering box mounted on the frame please?
Thank you.
Alex1 is offline   Reply With Quote
Old 04-11-2008, 06:12 PM   #2
jokersbowtie
jokersbowtie's Avatar
Re: Need a small favour, please!
will this help?
Stock, 305 4bbr, 4spd on the floor
http://www.cardomain.com/ride/2656721
jokersbowtie is offline   Reply With Quote
Old 04-11-2008, 06:17 PM   #3
Alex1
Alex1's Avatar
Perfect THANK YOU!
Old 04-11-2008, 06:18 PM   #4
Alex1
Alex1's Avatar
By the way how tough is it to steer?
Old 04-11-2008, 06:28 PM   #5
jokersbowtie
As long as your moving its not bad. sharp turns require 2 hands.
but i still dont drink and drive in stop and go traffic (also has a 4spd on the floor)
Old 04-12-2008, 03:38 AM   #6
benoit454
Chris
benoit454's Avatar
If you want to see how tough it is just unhook the belt from a power steer equip vehicle, truck prefferably, and try it out LOL.
As mentioned above, moving aint bad, but buddy sitting still turning is a PITA.
Our 76 had the pump of it for a lil bit after the 350 swap and it was tough.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-12-2008, 05:20 AM   #7
slugish
Slugish
lot harder to steer if you take belt off poweer steering pump thaN IT IS to steer with a manual steering box.
slugish is offline   Reply With Quote
Old 04-12-2008, 04:55 PM   #8
LONGHAIR
Yeah, quite a bit ^^^
LONGHAIR is offline   Reply With Quote
Old 04-12-2008, 06:23 PM   #9
84 400
Sb 400 club
84 400's Avatar
Manual is not that bad. I would defiantly loose the power steering for the turbo! It is a 1/2 ton and from the sounds of it not a daily driver. If you have never driven a manual steering truck I suggest you do before doing the swap. I had a 1977 dodge 1 1/4 ton 4x4 and at low speeds that thing was a bear. My arms got bigger but man parell parking was a night mare we often just found a dirt spot or open areas. At high speeds tho you could steer with one finger. I have never driven a half ton with manual steering but it has got to be easier. My willys wagon (rated at 1 ton from factory) has skinny tires on it and is easy to steer at slow speeds.
Just my experience
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
